Re: Diy reeds cut directly into Tomos case performance?
EH 📣FCC of the QCB /
Just a navigation tip are you using flat view or threaded view? Click on Flat view if your not.
If you want to make it case inducted go for it. But I would get another motor to play with. I would build that motor as is. Either make a new intake or modify that one. But like Jbot said with any real torque your going to tear that trans to shreds. People who have hard hitting Tomos motors spend a lot of time getting their clutches and gears right. Read Jake Cain’s thread about Toby. Good Tomos information. People put big kits and case induct e50s caus they can take more abuse.
It would be cool to see you try it, but if your doing case induction get good at aluminum welding or using the aluminum sticks with a good torch. Welding on cases that have been soaked in oil for years in not easy. I just don’t recommend doing that out the gate with out a backup plan.
Here it is......
Toby Race Bike (edited)
  Diy reeds cut directly into Tomos case performance?Topic by: J Dubbs J Dubbs 01/02/20 10:47AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 10:53AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 10:59AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 12:23PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 12:30PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 11:25AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 01:05PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 11:17AM
  Re: Diy reeds cut directly into Tomos case performance?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/02/20 01:39PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 01:43PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Thomas TPRF Thomas TPRF 01/02/20 02:37PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 01:54PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 02:36PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Cameron Cate Cameron Cate 01/02/20 04:50PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 05:08PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 06:31PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 08:06PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/02/20 10:45PM
  Re: Diy reeds cut directly into Tomos case performance?Re: P D P D 01/03/20 09:09AM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/03/20 10:50AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/03/20 01:15PM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/03/20 01:37PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/03/20 02:29PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/03/20 02:46PM
  Re: Diy reeds cut directly into Tomos case performance?Re: * * * * 01/03/20 03:02PM
  Re: Diy reeds cut directly into Tomos case performance?Re: niklaus _ niklaus _ 01/04/20 03:11AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/04/20 12:18PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/04/20 12:22PM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/05/20 09:32AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/05/20 05:58PM
