Re: Diy reeds cut directly into Tomos case performance?
Dirty30 Dillon /
I think you are over-complicating this a lot.
Case reeds are going to require much more fab than just making an intake for the Metra80.
You are stating that you "hate to lose the reeds" but honestly the Metra 80 is a GRUNTY cylinder that should have no problem moving just as it was designed. I would focus more on getting the motor built and fit to your frame, and less on how you can get reeds on the cylinder.
  Diy reeds cut directly into Tomos case performance?Topic by: J Dubbs J Dubbs 01/02/20 10:47AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 10:53AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 10:59AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 12:23PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 12:30PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 11:25AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 01:05PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 11:17AM
  Re: Diy reeds cut directly into Tomos case performance?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 01/02/20 01:39PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/02/20 01:43PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Thomas TPRF Thomas TPRF 01/02/20 02:37PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 01:54PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 02:36PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Cameron Cate Cameron Cate 01/02/20 04:50PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Dirty30 Dillon Dirty30 Dillon 01/02/20 05:08PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/02/20 06:31PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/02/20 08:06PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/02/20 10:45PM
  Re: Diy reeds cut directly into Tomos case performance?Re: P D P D 01/03/20 09:09AM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/03/20 10:50AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/03/20 01:15PM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/03/20 01:37PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/03/20 02:29PM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/03/20 02:46PM
  Re: Diy reeds cut directly into Tomos case performance?Re: * * * * 01/03/20 03:02PM
  Re: Diy reeds cut directly into Tomos case performance?Re: niklaus _ niklaus _ 01/04/20 03:11AM
  Re: Diy reeds cut directly into Tomos case performance?Re: Totally normal JBOT Totally normal JBOT 01/04/20 12:18PM
  Re: Diy reeds cut directly into Tomos case performance?Re: Daniel '' Daniel '' 01/04/20 12:22PM
  Re: Diy reeds cut directly into Tomos case performance?Re: . . . . 01/05/20 09:32AM
  Re: Diy reeds cut directly into Tomos case performance?Re: J Dubbs J Dubbs 01/05/20 05:58PM
