I'm still learning to navigate this excellent place to get information called the moped army lol..
So this morning I was reading about the e50 cutting reeds directly into the case and I couldn't help but wonder how much better or worse would it be to do that to a Tomos...
I did read someone overseas did it recently in July of 2019...
Has anyone else tried this or at least documented it...
I'm currently setting up my Tomos a55 with the 80cc metrakit now and although my cylinder and head is installed... The intake is going to look crappy... Plus it's piston ported and I hate the fact of losing my reeds...
So my question is you're such a nice flat spot on top of that engine where it looks like it would work and pull through the crankcase... I even think MLM makes an intake that's bigger than 20mm and I haven't checked yet... I have everything to do it and I guess I would cap off my cylinder with a gasket a piece of metal...
So I was curious about if it would be worth doing this or not and what everyone else's thoughts and comments were..
I'm pretty sure I would have enough clearance and room if I kept it toward the front of that hole over top of my crankcase...
Thank you and look forward to hearing any information or seeing any pictures....
Below is a picture of my current setup and I don't think my intake will work that way so I'm going to have to get a 1inch 45 degree copper plumbing elbow and add two more pieces of rubber and it's going to look like crap but it will clear after that....
