Over carbed ?
I dont want to over carb this ported engine, should a 125g spud be the optimum size, I have it jetted with a #70 right now but it will not run...
...suggestions???
Re: Over carbed ?
i would try some celery if your worried about carbs.
Re: Over carbed ?
Does it spudder on accel?
Re: Over carbed ?
Probably Fred /
I’m sorry you’re mistaken, that is not a carburetor, it is a battery,
Re: Over carbed ?
You’re missing an arugula filter
Re: Over carbed ?
Sour Cream with premix 20:1, and a little bit of dill.
Re: Over carbed ?
kevin smellaflange /
it'll have the breath of a dragon now....Drago-AZzzz
Re: Over carbed ?
Size 66 jellybean should be ball park jetting.
Re: Over carbed ?
Nice. Those Victoria engines are sweeeeet. Too bad ours had a broken clutch shoe and someone stripped the points screw on the stator. We ended up swapping it over to an av10. It was a lot more work than I thought it was gonna be...
Re: Over carbed ?
becane bits are low carb.
Re: Over carbed ?
Rick Bergsma /
Mopehu Maxx candy bar ?
Probably over carbed right there .
Re: Over carbed ?
I did not find the conversion extensive for AV7 or AV10 onto the Turismo or the Mini or the Maxi. Just used a AV8x head and trimmed the left two fins at the head mount for clearance for the mount on the frame.
The dang clutch arms are quite weak on the Torrot though, I have two busted to heck arms on the shelf of sadness.
Re: Over carbed ?
Your missing all the small pieces
Re: Over carbed ?
I need off this ride
