Will Peugeot 103, or Puch maxi forks, fit Honda Hobbit?
Hi everyone, I've read and Searched through the foruk but I can't find a definite answer to whether Peugeot 103 forks or Puch maxi forks would fit the Honda Hobbit without major modifications? I'm wondering whether the brake tabs would be an issue!! Thanks in advance, Luke
Re: Will Peugeot 103, or Puch maxi forks, fit Honda Hobbit?
103 forks have the right length and thread pitch to use all the hobbit head set bits. Puch maxi forks are shorter, have a shorter head tube and a 26mmx1 threading. You will have to switch out the brake plate on your hobbit wheel for a Leleu style brake stop though.
Fantastic thanks Daniel! Would I need to use the leleu brake for the Peugeot 103 forks too? Or just the Puch? Thanks mate
Doesn’t matter which bike as long as the axle is the correct size for the hobbit wheel. Iirc both puch maxi and Peugeot 103 have 11mm axle so it should work with either one.
Great thanks mate
