> Pops Peds Wrote:
> The carb on my stock qt50 has had too much tinkering with before i got
> it .i have decided to either buy new stock replacement or go with
> something that might work better ..i have seen some posts about running
> 15:15 sha on these .question is to those that have swaped if it is
> basicly plug and play or do i need to get other parts to make the change
> over before i order one..thanks in advance for any info on this
Same carb you would swap jets over and be okay. New carb you would have to tune it because the bike is now pulling in more air. If you can tune a bike, go bigger. If not get a direct replacement.
You will say ....what jet do I need for a bigger carb. The answer is idk? Every bike is different. So if you know a little about tuning a bike swap the carb. If not, get the same as the original. (edited)
