Re: Tomos a35 27 tooth front sprocket install
♣Slew Foot♣ /
The problem is when it goes wonky the chain will Bunch up and pinch in there and it will create its own brake in the cover and the case trust me I had this happen going around the corner and it totally wiped me it's like somebody throwing a stick in your tire so I'd be really careful and make sure your alignments are right because if your chain chain tensioner goes it's going to be quits it will actually lock the whole thing up at speed if you're lucky do I have enough space to fall where it can't touch the sprockets
