Re: Vespa 43mm Olympia kit jetting
Gle Cas /
> Richard Eberline Wrote:
> Try a 13/13 carb and a 66 main jet. b5hs plug .019. Will go mid forties
> with points.
> ARROW towards intake on the piston.
Arrow on the piston should be pointing towards the exhaust, not the intake.
And the carb size is relative to the intake size. If you have a 13 mm intake = go for the 13 mm carb. If your intake is 12 mm = stay with the 12 mm carb.
  Vespa 43mm Olympia kit jettingTopic by: Alek . Alek . 12/08/19 10:13AM
  Re: Vespa 43mm Olympia kit jettingRe: pat splat pat splat 12/08/19 12:44PM
  Re: Vespa 43mm Olympia kit jettingRe: - Joe - - Joe - 12/08/19 02:32PM
  Re: Vespa 43mm Olympia kit jettingRe: Gle Cas Gle Cas 12/09/19 06:33AM
  Re: Vespa 43mm Olympia kit jettingRe: Richard Eberline Richard Eberline 12/09/19 06:43AM
  Re: Vespa 43mm Olympia kit jettingRe: Gle Cas Gle Cas 12/09/19 11:55AM
  Re: Vespa 43mm Olympia kit jettingRe: Gle Cas Gle Cas 12/09/19 10:03PM
  Re: Vespa 43mm Olympia kit jettingRe: P D P D 12/10/19 09:51AM
  Re: Vespa 43mm Olympia kit jettingRe: Gle Cas Gle Cas 12/10/19 10:10AM
  Re: Vespa 43mm Olympia kit jettingRe: P D P D 12/10/19 10:19AM
  Re: Vespa 43mm Olympia kit jettingRe: Gle Cas Gle Cas 12/10/19 10:36AM
  Re: Vespa 43mm Olympia kit jettingRe: Graham Motzing Graham Motzing 12/09/19 12:43PM
  Re: Vespa 43mm Olympia kit jettingRe: Toledo Riot Toledo Riot 12/09/19 04:55PM
  Re: Vespa 43mm Olympia kit jettingRe: Graham Motzing Graham Motzing 12/09/19 05:34PM
  Re: Vespa 43mm Olympia kit jettingRe: Gle Cas Gle Cas 12/09/19 06:09PM
  Re: Vespa 43mm Olympia kit jettingRe: Toledo Riot Toledo Riot 12/10/19 09:41AM
  Re: Vespa 43mm Olympia kit jettingRe: Dirty30 Dillon Dirty30 Dillon 12/10/19 10:30AM
  Re: Vespa 43mm Olympia kit jettingRe: Alek . Alek . 12/10/19 12:48PM
  Re: Vespa 43mm Olympia kit jettingRe: Les B. Les B. 02/18/20 10:09AM
  Re: Vespa 43mm Olympia kit jettingRe: Dirty30 Dillon Dirty30 Dillon 02/18/20 10:15AM
  Re: Vespa 43mm Olympia kit jettingRe: Les B. Les B. 02/18/20 10:23AM
  Re: Vespa 43mm Olympia kit jettingRe: P D P D 02/18/20 10:55AM
  Re: Vespa 43mm Olympia kit jettingRe: pat splat pat splat 02/18/20 11:16AM
  Re: Vespa 43mm Olympia kit jettingRe: Richard Eberline Richard Eberline 02/18/20 03:34PM
  Re: Vespa 43mm Olympia kit jettingRe: Dirty30 Dillon Dirty30 Dillon 02/18/20 03:52PM
  Re: Vespa 43mm Olympia kit jettingRe: Les B. Les B. 02/18/20 06:26PM
  Re: Vespa 43mm Olympia kit jettingRe: Richard Eberline Richard Eberline 02/19/20 07:22AM
  Re: Vespa 43mm Olympia kit jettingRe: Dirty30 Dillon Dirty30 Dillon 02/19/20 09:37AM
  Re: Vespa 43mm Olympia kit jettingRe: P D P D 02/19/20 10:26AM
  Re: Vespa 43mm Olympia kit jettingRe: Dirty30 Dillon Dirty30 Dillon 02/19/20 10:36AM
  Re: Vespa 43mm Olympia kit jettingRe: P D P D 02/19/20 11:03AM
  Re: Vespa 43mm Olympia kit jettingRe: pat splat pat splat 02/19/20 12:15PM
  Re: Vespa 43mm Olympia kit jettingRe: Dirty30 Dillon Dirty30 Dillon 02/19/20 01:24PM
