Re: Top speed to expect from a Puch e50 stock top end?
Seth B /
> Overpriced Parts Wrote:
> > Graham Motzing Wrote:
> > oh yeah i meant to say the aluminum cylinders- in my experience-
> perform
> > better. they rev a lot higher out of the box, they are easier to port
> Yes aluminum cylinders rev out real good but don’t rule out using a
> Magnum top end, they make good all around power (magnum X even better)
> while using a magnum pipe fit on a maxi and just adding one 5/16 hole in
> down in a magnum pipe and then one hole in the endcap,
> open the intake hole on the cylinder a few mm and remove a bit of the
> skirt that protrudes in TDC, sand head down a bit (all puch heads need
> to be taken down somewhat)
> It’s almost like kitting and piping your bike, and many times you could
> get them free when people kit their bikes,
> A magnum cylinder has big fins has a lot of metal, runs cool at higher
> timings and magnum pipe has a chamber in it,
> I got a magnum II basically unported with those simple mods and stock
> pipe on it that beats most mild kitted bikes on take off and goes low
> 40s very reliably and I had a mild ported one on it before that went
> 45mph but after a few years and being old and used from the start anyway
> it wore out/ovaled,
Do Free Spirits come fitted with Magnum top ends and exhaust?
  Top speed to expect from a Puch e50 stock top end?Topic by: David McHugh David McHugh 12/03/19 06:49PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/03/19 07:07PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Seth B Seth B 12/03/19 10:36PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Ryan Graeme Ryan Graeme 12/04/19 12:25AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Seth B Seth B 12/04/19 09:42AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Dirty30 Dillon Dirty30 Dillon 12/04/19 09:58AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Graham Motzing Graham Motzing 12/04/19 10:17AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Probably Fred Probably Fred 12/04/19 01:15PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Seth B Seth B 12/04/19 01:57PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Potr zebie Potr zebie 12/06/19 09:54AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Garrett The Kid Garrett The Kid 12/04/19 12:55AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: * wormdirt * * wormdirt * 12/04/19 08:53AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Graham Motzing Graham Motzing 12/04/19 09:45AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Angry Hipster Angry Hipster 12/04/19 11:36AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Graham Motzing Graham Motzing 12/04/19 01:10PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Angry Hipster Angry Hipster 12/04/19 02:04PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Chöschi21 C.K. Chöschi21 C.K. 12/05/19 10:57AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Dan (high idle) Conway Dan (high idle) Conway 12/10/19 12:48PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: * * * * 12/10/19 10:26PM
