Re: Top speed to expect from a Puch e50 stock top end?
Probably Fred /
> Graham Motzing Wrote:
> oh yeah i meant to say the aluminum cylinders- in my experience- perform
> better. they rev a lot higher out of the box, they are easier to port
Yes aluminum cylinders rev out real good but don’t rule out using a Magnum top end, they make good all around power (magnum X even better) while using a magnum pipe fit on a maxi and just adding one 5/16 hole in down in a magnum pipe and then one hole in the endcap,
open the intake hole on the cylinder a few mm and remove a bit of the skirt that protrudes in TDC, sand head down a bit (all puch heads need to be taken down somewhat)
It’s almost like kitting and piping your bike, and many times you could get them free when people kit their bikes,
A magnum cylinder has big fins has a lot of metal, runs cool at higher timings and magnum pipe has a chamber in it,
I got a magnum II basically unported with those simple mods and stock pipe on it that beats most mild kitted bikes on take off and goes low 40s very reliably and I had a mild ported one on it before that went 45mph but after a few years and being old and used from the start anyway it wore out/ovaled,
  Top speed to expect from a Puch e50 stock top end?Topic by: David McHugh David McHugh 12/03/19 06:49PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/03/19 07:07PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Seth B Seth B 12/03/19 10:36PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Ryan Graeme Ryan Graeme 12/04/19 12:25AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Seth B Seth B 12/04/19 09:42AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Dirty30 Dillon Dirty30 Dillon 12/04/19 09:58AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Graham Motzing Graham Motzing 12/04/19 10:17AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Probably Fred Probably Fred 12/04/19 01:15PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Seth B Seth B 12/04/19 01:57PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Potr zebie Potr zebie 12/06/19 09:54AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Garrett The Kid Garrett The Kid 12/04/19 12:55AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: * wormdirt * * wormdirt * 12/04/19 08:53AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Graham Motzing Graham Motzing 12/04/19 09:45AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Angry Hipster Angry Hipster 12/04/19 11:36AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Graham Motzing Graham Motzing 12/04/19 01:10PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Angry Hipster Angry Hipster 12/04/19 02:04PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Chöschi21 C.K. Chöschi21 C.K. 12/05/19 10:57AM
  Re: Top speed to expect from a Puch e50 stock top end?Re: Dan (high idle) Conway Dan (high idle) Conway 12/10/19 12:48PM
  Re: Top speed to expect from a Puch e50 stock top end?Re: * * * * 12/10/19 10:26PM
