> Terbo Speghetti Wrote:
> > Zennon Krebsbach Wrote:
> > > Jack Rutherford Wrote:
> > > You can swap in a Honda Express CDI with flywheel and flywheel
> collar.
> > > You'll have to redo your wiring under the seat and go with a
> different
> > > coil.
> > That sounds harder and pricier than using a Hall effect sensor to
> > trigger the existing coil.
> Def gonna wanna see it if you do things this way.
Just take a stator, flywheel and flywheel collar from an 81-83 express and swap it in to the 80 or prior Express. Then you'll need to wire in the CDI and new ignition coil. I've done it before but I don't have the bike anymore.
I did the opposite on this engine. It was an 82 or 83 engine and I made it a points system by swapping in the stator, flywheel and flywheel collar. Underseat wiring was already for a points system.
