Re: Any Benefit To Converting From Points?
Jack Rutherford /
> Terbo Speghetti Wrote:
> > Zennon Krebsbach Wrote:
> > > Jack Rutherford Wrote:
> > > You can swap in a Honda Express CDI with flywheel and flywheel
> collar.
> > > You'll have to redo your wiring under the seat and go with a
> different
> > > coil.
> > That sounds harder and pricier than using a Hall effect sensor to
> > trigger the existing coil.
> Def gonna wanna see it if you do things this way.
Just take a stator, flywheel and flywheel collar from an 81-83 express and swap it in to the 80 or prior Express. Then you'll need to wire in the CDI and new ignition coil. I've done it before but I don't have the bike anymore.
I did the opposite on this engine. It was an 82 or 83 engine and I made it a points system by swapping in the stator, flywheel and flywheel collar. Underseat wiring was already for a points system.
  Any Benefit To Converting From Points?Topic by: Zennon Krebsbach Zennon Krebsbach 12/01/19 10:24PM
  Re: Any Benefit To Converting From Points?Re: Dan (high idle) Conway Dan (high idle) Conway 12/02/19 12:56AM
  Re: Any Benefit To Converting From Points?Re: live ɘvil live ɘvil 12/02/19 03:20AM
  Re: Any Benefit To Converting From Points?Re: Zennon Krebsbach Zennon Krebsbach 12/02/19 12:50PM
  Re: Any Benefit To Converting From Points?Re: Terbo Speghetti Terbo Speghetti 12/02/19 01:49PM
  Re: Any Benefit To Converting From Points?Re: Jack Rutherford Jack Rutherford 12/02/19 01:51PM
  Re: Any Benefit To Converting From Points?Re: Zennon Krebsbach Zennon Krebsbach 12/02/19 02:30PM
  Re: Any Benefit To Converting From Points?Re: live ɘvil live ɘvil 12/02/19 02:40PM
  Re: Any Benefit To Converting From Points?Re: Terbo Speghetti Terbo Speghetti 12/02/19 03:30PM
  Re: Any Benefit To Converting From Points?Re: Jack Rutherford Jack Rutherford 12/03/19 01:18PM
  Re: Any Benefit To Converting From Points?Re: Graham Motzing Graham Motzing 12/02/19 03:29PM
  Re: Any Benefit To Converting From Points?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 12/03/19 07:05PM
  Re: Any Benefit To Converting From Points?Re: Zennon Krebsbach Zennon Krebsbach 12/02/19 10:37PM
  Re: Any Benefit To Converting From Points?Re: Rebel Moby Rebel Moby 12/03/19 07:49PM
  Re: Any Benefit To Converting From Points?Re: Zennon Krebsbach Zennon Krebsbach 12/03/19 09:46PM
