> Zennon Krebsbach Wrote:
> > Jack Rutherford Wrote:
> > You can swap in a Honda Express CDI with flywheel and flywheel collar.
> > You'll have to redo your wiring under the seat and go with a different
> > coil.
> That sounds harder and pricier than using a Hall effect sensor to
> trigger the existing coil.
Def gonna wanna see it if you do things this way.
