Peugeot 103 Create Motor Wiring?
Does anyone have a wiring diagram for the 103 create motors? I haven’t seen these cdis any place else.
Re: Peugeot 103 Create Motor Wiring?
Post pics
A cdi is a cdi.
Powercoil
Trigger
Take the flywheel Off to look at what color wires go to the power coil and trigger. They should get you half way
Should have a connector on it that plugs right into the 5-pin cdi box.
There are a couple wires that come out of the cdi box wiring. The green/yellow is for a kill switch and the other wire runs to the high tension coil.
There is also a green/yellow from the stator that you ground. The other wires from the stator power your lights and any other accessories you have hooked up. That part can vary quite a bit actually. I've seen vogues, rcx, spx, etc that use that style cdi and the wiring isn't always identical.
create it yr self.
> tension coil.
> always identical.
I bought a second hand motor, the wires had been hacked up a bit, this clears it all up, thanks!
PS an external trigger? So I guess no changing the timing lol
