Re: Honda Hobbit PA50 low end power and gearing
> Nick / Ratbone Wrote:
> Definitely an improvement over a stock muffler in both sound and
> performance. Very throaty and low pitch. Perfect for 35mph stock-like
> builds. I actually did add some baffles and packing in this one, but I
> may build a few more and play around with a few different baffle
> orientations.
> Work on getting the belt as low as possible in front Vario, and as high
> as possible in the rear. so that you are starting in the lowest gear
> ratio possible. Every mm makes a noticeable difference in acceleration.
Dude that looks like catalytic converter.
Dude buy a 50cc kit , big carb and pipe.
If your worried about clearance you can obviously use a welder lol
