Av7 stock jug with Malossi 4petal!?
Been messing around with a stock av7 jug. Adapted a reed block plate from an old puch treat kit. Don’t know what’s going to happen!? Gotta firgure out the piston next.
Going to leave the exhaust port alone for now (edited)
Re: Av7 stock jug with Malossi 4petal!?
> Rebel Moby Wrote:
I just have one slight problem. The piston has windows for the transfers? I don’t know if this will effect anything.
I know that a yamaha jog small-end needle bearing will allow to use a 12mm piston. Maybe a puch piston? I dkn
Cuting piston in the next hour..say bye
Nope, you good. The cases still have to feed the transfers even with the reed.
Hope to get a quick run into nigth
Post results.
Making a video of it running. Crazy intake set up right so I have to drill start it. Running very rich on top end (edited)
test run
will jet tomorrow
What carb you running?
MAGIC INDEED
Obviously less hassle than trying to mod the carter for reeds...
19mm phbg lol. I know its probably over kill, i have a 15mm sha but I don’t have an intake set for it.
Not if you tune it right. I ran a 19.5 on a ported stock 1hp Garelli cylinder that I converted to reeds and a gigantor chamber.
I did this two years ago.
I went from 12-28mph with bearings, seals, gaskets, rings, porting and reed block.
Umm it’s not good, going to look into more. It revs really fucking high but goes absolutely no where. Gotta upgrade the transmission.
The transfers and exhaust ports are really low in the cylinder.
Like the belt is slipping? Single speed right? What gearing? 12/44?
Yea belt slip and yup Dimoby
You need to put an angle on the boost, it’s probably blowing the charge right out the exhaust. Also hogging it out all the way probably wasn’t the way to fly, I would have done it like Stephens with the smaller single channel and just enough material taken out for the reeds to fit in. (edited)
> in.
I will probably be buying a kit soon lol
> Rocco Taco Wrote:
> charge
> > in.
How high did you raise the exhaust? You can go wide but not over 2mm high before bottom end starts to suffer? I might have a few stock cylinders laying around and a bolt on av7 reed block if you really want to play with the idea
> > Rocco Taco Wrote:
> > charge
> wasn’t
> fit
> > > in.
I just committed to Something very naughty. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F352791422434
Say bye to av7 and hello av10! (edited)
> > > Rocco Taco Wrote:
> > > charge
> > wasn’t
> smaller
> > fit
> > > > in.
> want
NOOOOW you bout to spend some money......
> > > > Rocco Taco Wrote:
> > > > charge
> > > wasn’t
> > smaller
> to
> > > fit
> > > > > in.
> > want
Yes sir, Let’s do this! Might even snag that gila cylinder. The prices are so good
Be careful with those Gila cylinders. Gap your rings right, make sure the ring location pin is deep enough so it doesn't put pressure on the ring gap up against the cylinder wall and do the drop test on the Piston at 12,3,6 and 9:00 and make sure the Piston falls all the way through easily. If you fail to do any of this it will seize at stupid low temps and you'll be scratching your head trying to figure out why. Ask me how I know. Ignore any of it and you'll be doing the walk of shame.....
