Re: E50 + high (and adjustable) compression - spark plug = ....?
> Blaine- The artist formerly known as Plumber Crack "(OFMC)" Wrote:
> Without any rings on that contra-piston, you’ll never get this to run.
> I don’t think straight diesel fuel will get you there either.
> The smaller diesel model engines don’t have rings, but those small
> l pistons are lapped to size, and the cylinder bores have the slightest
> bit of taper. At tdc, the piston may actually feel stuck before the
> first few break in runs.
> I always ran all of mine on equal parts of ether, kerosene, and castor
> r oil.
> Regular “starting fluid” ether works fine, but be sure to read the
> e label, as not all starting fluids are the same. It should contain at
> least 70% ether. They recommend 2% of some kind of “stabilizer” to the
> mix also, but it’s not needed, and good luck finding it anyway.
> At room temperature it should fire on compression alone, but warming
> g the cylinder will help. My Mills diesel engines run cool, slow, and
> amazing quiet, but the Russian diesel i have will burn your face off,
> and it screams like a nitro.
Pics
  E50 + high (and adjustable) compression - spark plug = ....?Topic by: J MR J MR 11/14/19 05:01PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/14/19 05:03PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Angry Hipster Angry Hipster 11/14/19 05:56PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Ryan Graeme Ryan Graeme 11/15/19 12:17AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: pat splat pat splat 11/15/19 07:07AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:00AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Max (ツ) Max (ツ) 11/15/19 08:14AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:27AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:57AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 11/16/19 01:21AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Angry Hipster Angry Hipster 11/15/19 08:58AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 11:53PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Dirty30 Dillon Dirty30 Dillon 11/15/19 09:09AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Jeff Parr Jeff Parr 11/15/19 07:48PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 11:55PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Ryan Graeme Ryan Graeme 11/16/19 12:57AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: noah adelstein noah adelstein 11/16/19 12:05PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: river 2strokes river 2strokes 11/30/19 03:32PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: discontinuuity _ discontinuuity _ 11/16/19 03:48PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Kevin Bishop Kevin Bishop 11/23/19 03:55PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: discontinuuity _ discontinuuity _ 11/23/19 04:17PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/25/19 09:25AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Jeff Parr Jeff Parr 11/25/19 07:20PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Graham Motzing Graham Motzing 12/01/19 10:27AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/20/19 08:49AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 12/20/19 07:37PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/21/19 01:25AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 12/21/19 02:20AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/21/19 03:02AM
