Re: E50 + high (and adjustable) compression - spark plug = ....?
Without any rings on that contra-piston, you’ll never get this to run.
I don’t think straight diesel fuel will get you there either.
The smaller diesel model engines don’t have rings, but those small pistons are lapped to size, and the cylinder bores have the slightest bit of taper. At tdc, the piston may actually feel stuck before the first few break in runs.
I always ran all of mine on equal parts of ether, kerosene, and castor oil.
Regular “starting fluid” ether works fine, but be sure to read the label, as not all starting fluids are the same. It should contain at least 70% ether. They recommend 2% of some kind of “stabilizer” to the mix also, but it’s not needed, and good luck finding it anyway.
At room temperature it should fire on compression alone, but warming the cylinder will help. My Mills diesel engines run cool, slow, and amazing quiet, but the Russian diesel i have will burn your face off, and it screams like a nitro.
  E50 + high (and adjustable) compression - spark plug = ....?Topic by: J MR J MR 11/14/19 05:01PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/14/19 05:03PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Angry Hipster Angry Hipster 11/14/19 05:56PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Ryan Graeme Ryan Graeme 11/15/19 12:17AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: pat splat pat splat 11/15/19 07:07AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:00AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Max (ツ) Max (ツ) 11/15/19 08:14AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:27AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:57AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 11/16/19 01:21AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Angry Hipster Angry Hipster 11/15/19 08:58AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 11:53PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Dirty30 Dillon Dirty30 Dillon 11/15/19 09:09AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Jeff Parr Jeff Parr 11/15/19 07:48PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 11:55PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Ryan Graeme Ryan Graeme 11/16/19 12:57AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: noah adelstein noah adelstein 11/16/19 12:05PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: river 2strokes river 2strokes 11/30/19 03:32PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: discontinuuity _ discontinuuity _ 11/16/19 03:48PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Kevin Bishop Kevin Bishop 11/23/19 03:55PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: discontinuuity _ discontinuuity _ 11/23/19 04:17PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/25/19 09:25AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Jeff Parr Jeff Parr 11/25/19 07:20PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Graham Motzing Graham Motzing 12/01/19 10:27AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/20/19 08:49AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 12/20/19 07:37PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/21/19 01:25AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 12/21/19 02:20AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/21/19 03:02AM
