Re: E50 + high (and adjustable) compression - spark plug = ....?
Graham Motzing /
Hey this is pretty cool, I looked in to building one of these years ago but never cut chips. I think if you just turn the Piston flat and machine the head out for an insert with a flat bottom you'll be able to get it running. My thought was to use a glow plug from a rc airplane motor instead of adjust compression.
Doing a bunch of research into the lohman, it looks like you use the compression adjustment to get it started (high comp) then you turn it down to lower comp once it's warmed up and the rpms can then increase, controlled by the throttle. My original goal was to run on veg oil but I got cold on the idea once I realized I would have to mix it down with kerosene or something. Also you don't have to look to far for ether or methanol to cut down oil and make it light off easier, I have a torpedo heater I've had good luck running on waste oil mixed with gasoline instead of kerosene. Even 10 percent gas added to diesel or kerosene will make it light off really easy.
A guy I worked with put hydraulic oil in a Honda pressure washer once and it ran surprisingly well, in fact we couldn't figure out how to turn it off.
  E50 + high (and adjustable) compression - spark plug = ....?Topic by: J MR J MR 11/14/19 05:01PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/14/19 05:03PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Angry Hipster Angry Hipster 11/14/19 05:56PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Ryan Graeme Ryan Graeme 11/15/19 12:17AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: pat splat pat splat 11/15/19 07:07AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:00AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Max (ツ) Max (ツ) 11/15/19 08:14AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:27AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:57AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 11/16/19 01:21AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Angry Hipster Angry Hipster 11/15/19 08:58AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 11:53PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Dirty30 Dillon Dirty30 Dillon 11/15/19 09:09AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Jeff Parr Jeff Parr 11/15/19 07:48PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 11:55PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Ryan Graeme Ryan Graeme 11/16/19 12:57AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: noah adelstein noah adelstein 11/16/19 12:05PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: river 2strokes river 2strokes 11/30/19 03:32PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: discontinuuity _ discontinuuity _ 11/16/19 03:48PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Kevin Bishop Kevin Bishop 11/23/19 03:55PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: discontinuuity _ discontinuuity _ 11/23/19 04:17PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/25/19 09:25AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Jeff Parr Jeff Parr 11/25/19 07:20PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Graham Motzing Graham Motzing 12/01/19 10:27AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/20/19 08:49AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 12/20/19 07:37PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/21/19 01:25AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 12/21/19 02:20AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/21/19 03:02AM
