Re: E50 + high (and adjustable) compression - spark plug = ....?
J MR /
I think heat (or lack of heat) was my main problem when I tried to start it up last.
The piston, combustion chamber (a.k.a. "counter-piston"), and counter-piston sleeve (the thing that sits between the jug and head) are all aluminum, which sucks all the heat out.
Diesels like heat.
I have a few ideas to remedy. First I'll try using the ole' smokewrench to help preheat everything for startup. That probably won't work. So I suspect I'll end up switching to a cast-iron combustion chamber. Maybe cast-iron piston too, but I hope not; that thing took me a lot of time to make.
Surprised you didn't blow up your QT-50 motor! I've bored out the jug and case for larger top end bolts and am using a stronger race crank in hopes that I reduce the likelihood of breakage.
Also using a custom super heavy flywheel to help keep the motor spinning through the high compression. Have no need for a magneto, so it's basically just a hunk of steel, machined round.
  E50 + high (and adjustable) compression - spark plug = ....?Topic by: J MR J MR 11/14/19 05:01PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/14/19 05:03PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Angry Hipster Angry Hipster 11/14/19 05:56PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Ryan Graeme Ryan Graeme 11/15/19 12:17AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: pat splat pat splat 11/15/19 07:07AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:00AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Max (ツ) Max (ツ) 11/15/19 08:14AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:27AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 08:57AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 11/16/19 01:21AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Angry Hipster Angry Hipster 11/15/19 08:58AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 11:53PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Dirty30 Dillon Dirty30 Dillon 11/15/19 09:09AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Jeff Parr Jeff Parr 11/15/19 07:48PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/15/19 11:55PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Ryan Graeme Ryan Graeme 11/16/19 12:57AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: noah adelstein noah adelstein 11/16/19 12:05PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: river 2strokes river 2strokes 11/30/19 03:32PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: discontinuuity _ discontinuuity _ 11/16/19 03:48PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Kevin Bishop Kevin Bishop 11/23/19 03:55PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: discontinuuity _ discontinuuity _ 11/23/19 04:17PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: J MR J MR 11/25/19 09:25AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Jeff Parr Jeff Parr 11/25/19 07:20PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Graham Motzing Graham Motzing 12/01/19 10:27AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/20/19 08:49AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 12/20/19 07:37PM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/21/19 01:25AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: * * * * 12/21/19 02:20AM
  Re: E50 + high (and adjustable) compression - spark plug = ....?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 12/21/19 03:02AM
