Neato, right? They run am6 reedvalves. On air cooled kits, you need to cut usually like 2 fins though
Turkish replicas. The quality is amazing though. If only they made replicas of malossi mvr parts!!
I like! Wouldn't mind having a set myself.
I got them off Ebay. He sells them with either the case, seals, and intake, or all that stuff, and the reeds, bearings and stuff for like 60ish more. It came out cheaper then a polini case, has a bigger inlet, and I like the flow properties much better. Took like 2 weeks to get
Linky to his ebay store?
Beat me to it.
Sellers name is rouge-mobylette. Search "seller: rouge-mobylette" and pick that user.
I would link it for you guys but I couldn't figure out how from the eBay app.
Sellers site has lots of cool oem 103/51 parts.
Even has av10 46mm Gila kits and piston rings
Here's the seller's store : https://www.ebay.com/str/ROUGE-MOBYLETTE?_trksid=p2047675.l2563
Yup! That's him!
That’s legit. What would be the cylinder choice??
They two different branded cases are essentially the same but the Alim ones are machined a bit differently and have oiling holes drilled already.
Best part about them is you can use am6 and ktm 65 reeds. I found 3 used stock blocks with good reeds for $20 and the Vforce for $70 new on eBay.
There is also clone malossi am6 reeds for $7 on ebay
Here they are with some different reed blocks. Both ktm 65
There is also the Boyesen rad valve for 24mm carbs. One piece intake/reed block.
They already sold out?
Have to wait until he restocks...
...lots of other goodies on his ebay store as well...
Sorry guys. Didnt realize he was out now
They wont work unless you have the odd Bikelete ignition.
> Rocco Taco Wrote:
> ALibaba is awesome!
> https://m.alibaba.com/product/50020206298/Pull-Starter-BIKELETE-for-MBK-AV10.html
> > Rocco Taco Wrote:
> > ALibaba is awesome!
Thanks for the heads up! I wanted to buy it.
Can some explain the prices on this website. https://www.bikeleteloja.com.br/carter-4-palhetas-motor-mobilete-competicao
That's Portuguese language and a Brazilian site .
Their money is called Brazilian Real . A single Real is equal to just under 24 American cents .
Yea but do they mean 206.91 Brazilian real? That’s only $49 usd!? they even have frames. I’m trying to email them but I never have good luck with foreign companies (big language barrier) lol. Maybe I corner them on alibabe and convince them to post more stuff on there.
49 bucks might be exactly what they want .
We have to remember that the Brazilian economy is pretty much still in the shitter .
> the shitter .
well I’ll be more then happy to send money in there direction
> > the shitter .
49 is cheap enough , but , I don't know how much they want for S & H .
woah! those are rad
makes me want to build an AV10
The gasket in these kit sucks! It doesn’t line up at all, I battled with the case for like 1 hour to find out a piece of the gasket got cut off and jammed in the inner lip.
The gasket that came with minebroke in half when I took it out of the box.
Cut a new one from some thin paper and copper spray it
When I mocked mine up there is enough clearance to ditch the gasket and use sealant instead.
