Over-revving
Drake Abrahamsson /
I’m not worried that this is currently happening to me however I’d like to know the symptoms/ signs of overrevving, pertaining to a too low gear ratio. I’m just starting to change up gearing. The PO had a 16/35 and I never counted it until late into the rebuild. I’d always thought that the bike had less than optimal torque. After some reading and analyzing, I’m switching to 16/40.
This is an e50 with a treats 70cc piston port kit.
Once again, I don’t think that this is an issue for me, I am just curious! Tried searching a few different things but couldn’t find anything, perhaps I am using the wrong diction
Re: Over-revving
Overpriced Parts /
You got ratio backwards, 16×35 is a higher gearing, ratio, 16x40 is lower gearing ratio,
16-17x40 is fine for piston port kitted e50.
Re: Over-revving
Drake Abrahamsson /
Thank you for the reassurance! What would be a characteristic of a ratio that is too low? Once again, just curious. Hot running? Early bearing wear? Any noises?
Re: Over-revving
Overpriced Parts /
16-17x40 is fine, overheating can be a timing/tuning issue and bearing noise and such shouldn't be an issue if you did a rebuild with a needle bearing crank,
