Cobra Sito 2 Restrictions
Josiah Radebaugh /
I bought this dope NOS Cobra pipe from Italy for my mild SP build right... Well Its awfull restrictive about as restrictive as a stock, de-restricted pipe. Anyone have any experience or knowledge with these pipes and how they were restricted? I don't really want to soil the NOS goodness but I know It has more to offer. (edited)
Re: Cobra Sito 2 Restrictions
If you dont see the restriction coin in the header pipe then it is likely choked down in the silencer section.
Josiah Radebaugh /
All I have to do is figure out how to remove that baffle cap then...
Why not simply cut the weld at the front of the can ?
Josiah Radebaugh /
As mentioned, I'd rather not soil this NOS pipe. Also, I don't currently have any gas and do not trust thick flux wire to not just blow holes in it.
Dirty30 Dillon /
Typically, those baffles are riveted, and than pressed into the welded on outer part. I had to use a slide hammer to remove my Alsil baffle
Josiah Radebaugh /
Mine has an Allen screw and a nut, after removing that it still seems quite tight. May be pressed in...
Dirty30 Dillon /
Slide hammer, or clamp some needle nose vice grips on there and whack away
Then cope with the reduced speed until you have shield gas
> it.
Josiah Radebaugh /
It was indeed a baffle pressed in the end. Much higher flow now.
Not much louder though.... Thank ya'
Excellent
