Re: Peugeot 103 70cc Metrakit
Jesse Simonsen /
> DrGeorgeTompson (Alan) Wrote:
> > Stephen Simmons Wrote:
> > > Jansen Hanzer Wrote:
> > > use a real pipe
> > > you are wasting your time
> > > putting lipstick on a pig
> > > ok thank you
> > This may be true but the right modified pug stock exhaust has done
> 45-50
> > mph. There is no fun in just bolting stuff on either. So to say
> someone
> > is waisting their time is BS......
> Yeah I got 47 on the stock pipe with cracked header welds lol. I don't
> think I'm wasting time, but I'm definitely not wasting money. I like
> messing with these things probably more than I like riding them. I ride
> to work every day all year; I get enough of that. I'm pretty much just
> waiting for stuff to break so I can fix it.
> ALSO, I mocked up the banana blaster last night. I would need to move
> the mounting bracket on the pipe back but thats fine because it's in a
> terrible spot anyway and there's a lot of rearward weight on it. With a
> ball joint, it should fit and will shoot out less upwards than when
> mounted on a flatreed. It should clear the centerstand but I will need
> to extend the pedal. NBD. Prolly gonna do that but I don't think it will
> be for a while.
> Do other springs like the Doppler fit the polini spring thingy? I can't
> reuse the stock spring. Maybe I'll get a gas piston too. Polini spring
> too soft.
> I haven't messed with the weights yet. I might just try running some
> nuts or something. Maybe trim the weights a bit. I'll mess with the
> variator today.
Go to Ace Hardware or the equivalent in your area and buy some springs that match the OD of the polini spring.
Also get some skinny ones to slip inside the bigger one.
You can get get them for a few dollars a piece and cut them and experiment. Make them a bit longer so you can preload them or make some dual rate springs.
If you put a gas spring on make sure its mounted to match the movement of the engine. I've had the mounts break and the shock explode from slight alignment issues .
Love that you got that stock pipe on there.
  Peugeot 103 70cc MetrakitTopic by: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 02:31PM
  Re: Peugeot 103 70cc MetrakitRe: Graham Motzing Graham Motzing 10/28/19 02:55PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 03:09PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 10/28/19 03:17PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 10/28/19 04:22PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 04:36PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 10/28/19 04:39PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 04:51PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 10/29/19 12:26PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 12:58PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 10/29/19 01:29PM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 11/03/19 03:12AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/03/19 09:26PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 09:39PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/03/19 09:59PM
  Re: Peugeot 103 70cc MetrakitRe: Joey P Joey P 11/05/19 12:52PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 12:55PM
  Re: Peugeot 103 70cc MetrakitRe: T y l e r T y l e r 11/21/19 12:17AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 10:02AM
  Re: Peugeot 103 70cc MetrakitRe: cheetahchrome . cheetahchrome . 10/29/19 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 10:33AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 02:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 02:58PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/30/19 10:10AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 10/29/19 03:50PM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 10/29/19 09:17PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/30/19 10:03AM
  Re: Peugeot 103 70cc MetrakitRe: scrot rash scrot rash 10/30/19 10:45AM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 10/30/19 03:19PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 08:40AM
  Re: Peugeot 103 70cc MetrakitRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/03/19 12:18PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 08:37PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 08:47AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 03:00PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 03:16PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 12:08PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/04/19 12:21PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/04/19 12:36PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/04/19 04:51PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/04/19 07:39PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/04/19 07:39PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 09:26AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/05/19 12:56PM
  Re: Peugeot 103 70cc MetrakitRe: Joey P Joey P 11/05/19 01:07PM
  Re: Peugeot 103 70cc MetrakitRe: Eric N Eric N 11/07/19 03:59PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/07/19 05:03PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/08/19 04:27PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/08/19 05:17PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/08/19 09:36PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/08/19 11:21PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 08:20AM
  Re: Peugeot 103 70cc MetrakitRe: Jesse Simonsen Jesse Simonsen 11/09/19 01:07PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 02:36PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/09/19 04:00PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 04:05PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/09/19 04:10PM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 11/09/19 11:54PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/10/19 03:03PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/10/19 05:41PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/10/19 08:13PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/10/19 08:23PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 10:25AM
  Re: Peugeot 103 70cc MetrakitRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 11/13/19 11:11AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 11:22AM
  Re: Peugeot 103 70cc MetrakitRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 11/13/19 11:38AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 06:37PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/14/19 12:13PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/14/19 12:14PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/14/19 12:56PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty Mike Dirty Mike 11/14/19 06:32PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/14/19 10:46PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/14/19 07:22PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/14/19 08:48PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/15/19 10:48AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/15/19 06:04PM
  Re: Peugeot 103 70cc MetrakitRe: Blake MD No PM Plz Blake MD No PM Plz 11/15/19 06:16PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/15/19 10:04AM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 11/16/19 07:37AM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 09:47AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/16/19 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 12:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/16/19 01:25PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 02:09PM
  Re: Peugeot 103 70cc MetrakitRe: Jesse Simonsen Jesse Simonsen 11/17/19 11:27AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/18/19 03:19PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/19/19 11:34AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/19/19 02:36PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/19/19 11:04PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/20/19 07:20AM
  Re: Peugeot 103 70cc MetrakitRe: Chris Szuba Chris Szuba 11/21/19 06:16AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 05:10PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/21/19 06:25PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 07:20PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 08:47PM
  Re: Peugeot 103 70cc MetrakitRe: Tyler Hautau Tyler Hautau 11/22/19 07:58AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/22/19 08:51PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/23/19 10:30AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/23/19 01:04PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty Mike Dirty Mike 11/23/19 01:25PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/24/19 03:34PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/25/19 12:34PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/25/19 12:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/01/19 07:38PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 11:15AM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 12/10/19 11:37AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 12:12PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 12/10/19 07:52PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/13/19 09:26AM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 12/10/19 10:32PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/12/19 10:16AM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 12/12/19 10:54AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/12/20 01:45PM
  Re: Peugeot 103 70cc MetrakitRe: Graham Motzing Graham Motzing 08/13/20 11:21AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 11:20AM
  Re: Peugeot 103 70cc MetrakitRe: Jay Rivett Jay Rivett 08/12/20 04:21PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/09/20 12:17PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/15/20 11:14AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 12:43PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 07:03PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 09/15/20 08:16PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 10:04PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/09/20 01:16PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 09/10/20 04:15PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 09:32AM
  Re: Peugeot 103 70cc MetrakitRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/15/20 09:44AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 12:36PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 02:23PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 09/15/20 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/16/20 11:31AM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/16/20 11:36AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 09/16/20 11:41AM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/16/20 12:32PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/16/20 11:45AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 11:55AM
  Re: Peugeot 103 70cc MetrakitRe: Toledo Riot Toledo Riot 09/16/20 01:20PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 02:06PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/16/20 03:23PM
  Re: Peugeot 103 70cc MetrakitRe: Aaron Blair Aaron Blair 09/16/20 10:19PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 10:24PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/17/20 01:14PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 09/17/20 02:01PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/17/20 02:29PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/07/20 02:24PM
