Re: Peugeot 103 70cc Metrakit
DrGeorgeTompson (Alan) /
Ok, so I ended up using way less base gasket than i thought. Putting a thicc helping of Dykem blue on the spacer and tapping the inked spacer on the gasket paper worked really well. I've gotten it down pretty well.
If you don't have a punch set, you are doing it wrong. Makes so many holes so easy. I used to punch the base gaskets and to open the holes on the head gasket and exhaust gasket from this to fit. it was lit. Also note: that flange is angled so i can mount it the best orientation to fit the pipe. i think it's gonna work well.
Initially i had cut a .5 and .85 gasket. I could barely measure the squish (@ ~2mm) with no head gasket (.5 mm). So i made 2 more at .3mm. The total gasket stack (including head) ends up a 1.1mm. The base spacing was (4.5+.6 = ~5.1mm) Probably closer to 5mm once compressed. and i may have taken some material off the spacer at some point but it's likely negligible.
Anyways, that leaves the squish at about 1.7mm the piston ring is just barely visible at bdc; the compression is right around 120psi. I'm kinda butthurt how low it is, but it will probably run forever if all goes well.
The top end is comically larger than the bottom.
  Peugeot 103 70cc MetrakitTopic by: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 02:31PM
  Re: Peugeot 103 70cc MetrakitRe: Graham Motzing Graham Motzing 10/28/19 02:55PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 03:09PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 10/28/19 03:17PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 10/28/19 04:22PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 04:36PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 10/28/19 04:39PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 04:51PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 10/29/19 12:26PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 12:58PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 10/29/19 01:29PM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 11/03/19 03:12AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/03/19 09:26PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 09:39PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/03/19 09:59PM
  Re: Peugeot 103 70cc MetrakitRe: Joey P Joey P 11/05/19 12:52PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 12:55PM
  Re: Peugeot 103 70cc MetrakitRe: T y l e r T y l e r 11/21/19 12:17AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 10:02AM
  Re: Peugeot 103 70cc MetrakitRe: cheetahchrome . cheetahchrome . 10/29/19 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 10:33AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 02:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 02:58PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/30/19 10:10AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 10/29/19 03:50PM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 10/29/19 09:17PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/30/19 10:03AM
  Re: Peugeot 103 70cc MetrakitRe: scrot rash scrot rash 10/30/19 10:45AM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 10/30/19 03:19PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 08:40AM
  Re: Peugeot 103 70cc MetrakitRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/03/19 12:18PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 08:37PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 08:47AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 03:00PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 03:16PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 12:08PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/04/19 12:21PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/04/19 12:36PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/04/19 04:51PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/04/19 07:39PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/04/19 07:39PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 09:26AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/05/19 12:56PM
  Re: Peugeot 103 70cc MetrakitRe: Joey P Joey P 11/05/19 01:07PM
  Re: Peugeot 103 70cc MetrakitRe: Eric N Eric N 11/07/19 03:59PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/07/19 05:03PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/08/19 04:27PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/08/19 05:17PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/08/19 09:36PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/08/19 11:21PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 08:20AM
  Re: Peugeot 103 70cc MetrakitRe: Jesse Simonsen Jesse Simonsen 11/09/19 01:07PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 02:36PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/09/19 04:00PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 04:05PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/09/19 04:10PM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 11/09/19 11:54PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/10/19 03:03PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/10/19 05:41PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/10/19 08:13PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/10/19 08:23PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 10:25AM
  Re: Peugeot 103 70cc MetrakitRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 11/13/19 11:11AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 11:22AM
  Re: Peugeot 103 70cc MetrakitRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 11/13/19 11:38AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 06:37PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/14/19 12:13PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/14/19 12:14PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/14/19 12:56PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty Mike Dirty Mike 11/14/19 06:32PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/14/19 10:46PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/14/19 07:22PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/14/19 08:48PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/15/19 10:48AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/15/19 06:04PM
  Re: Peugeot 103 70cc MetrakitRe: Blake MD No PM Plz Blake MD No PM Plz 11/15/19 06:16PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/15/19 10:04AM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 11/16/19 07:37AM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 09:47AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/16/19 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 12:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/16/19 01:25PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 02:09PM
  Re: Peugeot 103 70cc MetrakitRe: Jesse Simonsen Jesse Simonsen 11/17/19 11:27AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/18/19 03:19PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/19/19 11:34AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/19/19 02:36PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/19/19 11:04PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/20/19 07:20AM
  Re: Peugeot 103 70cc MetrakitRe: Chris Szuba Chris Szuba 11/21/19 06:16AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 05:10PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/21/19 06:25PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 07:20PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 08:47PM
  Re: Peugeot 103 70cc MetrakitRe: Tyler Hautau Tyler Hautau 11/22/19 07:58AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/22/19 08:51PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/23/19 10:30AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/23/19 01:04PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty Mike Dirty Mike 11/23/19 01:25PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/24/19 03:34PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/25/19 12:34PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/25/19 12:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/01/19 07:38PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 11:15AM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 12/10/19 11:37AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 12:12PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 12/10/19 07:52PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/13/19 09:26AM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 12/10/19 10:32PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/12/19 10:16AM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 12/12/19 10:54AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/12/20 01:45PM
  Re: Peugeot 103 70cc MetrakitRe: Graham Motzing Graham Motzing 08/13/20 11:21AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 11:20AM
  Re: Peugeot 103 70cc MetrakitRe: Jay Rivett Jay Rivett 08/12/20 04:21PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/09/20 12:17PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/15/20 11:14AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 12:43PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 07:03PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 09/15/20 08:16PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 10:04PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/09/20 01:16PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 09/10/20 04:15PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 09:32AM
  Re: Peugeot 103 70cc MetrakitRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/15/20 09:44AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 12:36PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 02:23PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 09/15/20 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/16/20 11:31AM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/16/20 11:36AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 09/16/20 11:41AM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/16/20 12:32PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/16/20 11:45AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 11:55AM
  Re: Peugeot 103 70cc MetrakitRe: Toledo Riot Toledo Riot 09/16/20 01:20PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 02:06PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/16/20 03:23PM
  Re: Peugeot 103 70cc MetrakitRe: Aaron Blair Aaron Blair 09/16/20 10:19PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 10:24PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/17/20 01:14PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 09/17/20 02:01PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/17/20 02:29PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/07/20 02:24PM
