Peugeot 103 70cc Metrakit
DrGeorgeTompson (Alan) /
https://www.treatland.tv/peugeot-103-70cc-47mm-metrakit-w-head-p/peugeot-metrakit-010810247.htm
Anyone else building one of these? I know Tomahawk built one, but he keeps his secrets pretty close.
I'm a cheap bastard and the $120 price tag for a kit that I know and love with a decompless head seemed too good to be true. BIG ASS vertical fins, thicc nasty head, gotta be a dope air cooled rig, amirite? Naturally, i totally ignore treats disclaimer at the bottom because how bad could it be? lel RIP
I'm probably 8 or so hours (maybe more maybe less idk, most of it is drinking beer and getting metal shavings out of my eyes) into building it and it's been a lot of work. but i'm very excited.
I "bored" the case with a big sanding drum (1.5" i think) on a drill and it worked surprisingly well and I am pleased with the results. I hand bored a bat case way back in the day with a dremel and i think the drum method is much more consistent and provides a better result. Big drum removes material very evenly. I kept test fitting the Cylinder and removing the high spots that get shiny when you try to jam the bitch in. I Used the spacer that treats sells as a guide for the bore diameter.
The fins in the back are easy, i just cut them a bit with an angle grinder. you don't need to remove much and it's only the outer two that would hit the motor mounts.
Even with the spacer, The cylinder skirt is too long to fit into the polini cases without collisions; im not sure about the stock cases, but i imagine it's similar. so i cut off about 25% of it and now it fits very well.
I rough cut the big polini transfers into the spacer last night and plan to open the transfers on the kit itself to match. Lot of dremel work to do still.
The boom boom zone of the 50cc head it comes with is too damn small, so i used the included head gasket to mark the diameter for the 70cc piston. I screwed a sparkplug into the head upside down and used the threaded nipple to chuck it into my small af drill press and spun the head while working it with a dremel. the shit chatters all over so you get really terrible "machining" marks, but it cleaned up really well with some sand paper. I'll lap it on some glass when im pleased with the profile.
I'll try to grab more pictures tonight. I have been really bad about documenting this.
I'm doing all this just to run stock points, stock trans, a stock pipe and idgaf. they can hear me motor grunting from 3.5 blocks away. oh lawd he coming (edited)
  Peugeot 103 70cc MetrakitTopic by: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 02:31PM
  Re: Peugeot 103 70cc MetrakitRe: Graham Motzing Graham Motzing 10/28/19 02:55PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 03:09PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 10/28/19 03:17PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 10/28/19 04:22PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 04:36PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 10/28/19 04:39PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/28/19 04:51PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 10/29/19 12:26PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 12:58PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 10/29/19 01:29PM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 11/03/19 03:12AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/03/19 09:26PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 09:39PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/03/19 09:59PM
  Re: Peugeot 103 70cc MetrakitRe: Joey P Joey P 11/05/19 12:52PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 12:55PM
  Re: Peugeot 103 70cc MetrakitRe: T y l e r T y l e r 11/21/19 12:17AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 10:02AM
  Re: Peugeot 103 70cc MetrakitRe: cheetahchrome . cheetahchrome . 10/29/19 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 10:33AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 02:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/29/19 02:58PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/30/19 10:10AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 10/29/19 03:50PM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 10/29/19 09:17PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/30/19 10:03AM
  Re: Peugeot 103 70cc MetrakitRe: scrot rash scrot rash 10/30/19 10:45AM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 10/30/19 03:19PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 08:40AM
  Re: Peugeot 103 70cc MetrakitRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 11/03/19 12:18PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 08:37PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 08:47AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 03:00PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/02/19 03:16PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/03/19 12:08PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/04/19 12:21PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/04/19 12:36PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/04/19 04:51PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/04/19 07:39PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/04/19 07:39PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/05/19 09:26AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/05/19 12:56PM
  Re: Peugeot 103 70cc MetrakitRe: Joey P Joey P 11/05/19 01:07PM
  Re: Peugeot 103 70cc MetrakitRe: Eric N Eric N 11/07/19 03:59PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/07/19 05:03PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/08/19 04:27PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/08/19 05:17PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/08/19 09:36PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/08/19 11:21PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 08:20AM
  Re: Peugeot 103 70cc MetrakitRe: Jesse Simonsen Jesse Simonsen 11/09/19 01:07PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 02:36PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/09/19 04:00PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/09/19 04:05PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/09/19 04:10PM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 11/09/19 11:54PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/10/19 03:03PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/10/19 05:41PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/10/19 08:13PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/10/19 08:23PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 10:25AM
  Re: Peugeot 103 70cc MetrakitRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 11/13/19 11:11AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 11:22AM
  Re: Peugeot 103 70cc MetrakitRe: ᴛᴇʀʀʏ ᴅᴇᴀɴ ᴛᴇʀʀʏ ᴅᴇᴀɴ 11/13/19 11:38AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/13/19 06:37PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/14/19 12:13PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/14/19 12:14PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/14/19 12:56PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty Mike Dirty Mike 11/14/19 06:32PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/14/19 10:46PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/14/19 07:22PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/14/19 08:48PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/15/19 10:48AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 11/15/19 06:04PM
  Re: Peugeot 103 70cc MetrakitRe: Blake MD No PM Plz Blake MD No PM Plz 11/15/19 06:16PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/15/19 10:04AM
  Re: Peugeot 103 70cc MetrakitRe: Jansen Hanzer Jansen Hanzer 11/16/19 07:37AM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 09:47AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/16/19 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 12:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/16/19 01:25PM
  Re: Peugeot 103 70cc MetrakitRe: Stephen Simmons Stephen Simmons 11/16/19 02:09PM
  Re: Peugeot 103 70cc MetrakitRe: Jesse Simonsen Jesse Simonsen 11/17/19 11:27AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/18/19 03:19PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/19/19 11:34AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/19/19 02:36PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 11/19/19 11:04PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/20/19 07:20AM
  Re: Peugeot 103 70cc MetrakitRe: Chris Szuba Chris Szuba 11/21/19 06:16AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 05:10PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/21/19 06:25PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 07:20PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/21/19 08:47PM
  Re: Peugeot 103 70cc MetrakitRe: Tyler Hautau Tyler Hautau 11/22/19 07:58AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/22/19 08:51PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/23/19 10:30AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 11/23/19 01:04PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty Mike Dirty Mike 11/23/19 01:25PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/24/19 03:34PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 11/25/19 12:34PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 11/25/19 12:50PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/01/19 07:38PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 11:15AM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 12/10/19 11:37AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 12:12PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 12/10/19 07:52PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/13/19 09:26AM
  Re: Peugeot 103 70cc MetrakitRe: * * * * 12/10/19 10:32PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/12/19 10:16AM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 12/12/19 10:54AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 08/12/20 01:45PM
  Re: Peugeot 103 70cc MetrakitRe: Graham Motzing Graham Motzing 08/13/20 11:21AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/10/19 11:20AM
  Re: Peugeot 103 70cc MetrakitRe: Jay Rivett Jay Rivett 08/12/20 04:21PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/09/20 12:17PM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/15/20 11:14AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 12:43PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 07:03PM
  Re: Peugeot 103 70cc MetrakitRe: P D P D 09/15/20 08:16PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 10:04PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/09/20 01:16PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 09/10/20 04:15PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 09:32AM
  Re: Peugeot 103 70cc MetrakitRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/15/20 09:44AM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/15/20 12:36PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/15/20 02:23PM
  Re: Peugeot 103 70cc MetrakitRe: Charlie BUZZARD Charlie BUZZARD 09/15/20 10:14AM
  Re: Peugeot 103 70cc MetrakitRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/16/20 11:31AM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/16/20 11:36AM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 09/16/20 11:41AM
  Re: Peugeot 103 70cc MetrakitRe: Dirty30 Dillon Dirty30 Dillon 09/16/20 12:32PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/16/20 11:45AM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 11:55AM
  Re: Peugeot 103 70cc MetrakitRe: Toledo Riot Toledo Riot 09/16/20 01:20PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 02:06PM
  Re: Peugeot 103 70cc MetrakitRe: EH FCC of the QCB EH FCC of the QCB 09/16/20 03:23PM
  Re: Peugeot 103 70cc MetrakitRe: Aaron Blair Aaron Blair 09/16/20 10:19PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/16/20 10:24PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/17/20 01:14PM
  Re: Peugeot 103 70cc MetrakitRe: Daniel '' Daniel '' 09/17/20 02:01PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/17/20 02:29PM
  Re: Peugeot 103 70cc MetrakitRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/07/20 02:24PM
