Re: Stock Tomos A35 Parmakit CDI
Graham Motzing /
yeah its an apples-to-eggs comparison but when i was running a Jog (retarding) cdi on a puch with a treats stator on a polini i had the base timing set at 1.8 ( 22*) and it would retard to 1.3 (18*)-ish and ran perfecto (until the trigger coil failed)
i think it make sense and helps alot when fucking with CDI's to put timing marks on your flywheel and go off degrees since its universal. Puch/ tomos are basically the same dims for stroke and con rod but other info you find has to be translated betwen degrees and length.
  Stock Tomos A35 Parmakit CDITopic by: Dan (high idle) Conway Dan (high idle) Conway 10/26/19 03:39PM
  Re: Stock Tomos A35 Parmakit CDIRe: Dan (high idle) Conway Dan (high idle) Conway 10/26/19 09:12PM
  Re: Stock Tomos A35 Parmakit CDIRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/26/19 09:45PM
  Re: Stock Tomos A35 Parmakit CDIRe: Daniel '' Daniel '' 10/26/19 10:17PM
  Re: Stock Tomos A35 Parmakit CDIRe: Garelli Master✨ Garelli Master✨ 10/26/19 10:19PM
  Re: Stock Tomos A35 Parmakit CDIRe: Daniel '' Daniel '' 10/27/19 07:28PM
  Re: Stock Tomos A35 Parmakit CDIRe: Dan (high idle) Conway Dan (high idle) Conway 10/27/19 11:04PM
  Re: Stock Tomos A35 Parmakit CDIRe: Garelli Master✨ Garelli Master✨ 10/28/19 04:54AM
  Re: Stock Tomos A35 Parmakit CDIRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/27/19 11:40AM
  Re: Stock Tomos A35 Parmakit CDIRe: Dan (high idle) Conway Dan (high idle) Conway 10/27/19 01:03AM
  Re: Stock Tomos A35 Parmakit CDIRe: Dan (high idle) Conway Dan (high idle) Conway 10/27/19 06:07PM
  Re: Stock Tomos A35 Parmakit CDIRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/27/19 06:46PM
  Re: Stock Tomos A35 Parmakit CDIRe: Dan (high idle) Conway Dan (high idle) Conway 10/27/19 11:05PM
  Re: Stock Tomos A35 Parmakit CDIRe: Graham Motzing Graham Motzing 10/28/19 11:29AM
  Re: Stock Tomos A35 Parmakit CDIRe: Dan (high idle) Conway Dan (high idle) Conway 10/28/19 12:53PM
  Re: Stock Tomos A35 Parmakit CDIRe: P D P D 10/28/19 01:17PM
  Re: Stock Tomos A35 Parmakit CDIRe: Graham Motzing Graham Motzing 10/28/19 02:57PM
  Re: Stock Tomos A35 Parmakit CDIRe: Dan (high idle) Conway Dan (high idle) Conway 10/29/19 12:07AM
  Re: Stock Tomos A35 Parmakit CDIRe: ♣Slew Foot♣ ♣Slew Foot♣ 10/29/19 07:48AM
  Re: Stock Tomos A35 Parmakit CDIRe: Tomos Rider Tomos Rider 09/20/22 11:09PM
  Re: Stock Tomos A35 Parmakit CDIRe: Dave & Bummerzz Dave & Bummerzz 11/01/19 10:30AM
