Re: Sleeper A55 ideas
Buttcheeks BUZZARD /
Spacing the cylinder up so that the exhaust clears all the way and decking the head and making a good squish band helps a lot too. Also the stock ignition will work great for forever. Recently I took a cutting wheel to the starter gears on the flywheel and cut them off. Made a big difference taking all that weight off the flywheel
