Re: Puch E50 Clutch Fluid Adventures
> Graham Motzing Wrote:
> > Brad William Wrote:
> > Is it really the case that slip/lubricity/viscosity are the only
> > variables to all of the above? I was of the impression that some
> fluids
> > were more/less compatible with the clutch pad material itself. Don't
> > some formulations, never intended for wet clutch use, deteriorate the
> > pads chemically?
> so this is pretty complicated because there are a number of different
> materials/chemicals at play. i've never experienced any chemical
> reaction problems from running different oils, but the rubber clutch in
> a Garelli NOI is the big one.
> for the most part all of these oils are pretty chemically inert with the
> clutch and seal materials in the transmission. The a35 cork could be
> another one that would be harmed by detergent or solvents in the oil,
> but those probably won't live long enough to need it.
> interesting about the rotella in the A35's, i've always ran those with
> ATF because i usually go to asbestos linings on the more powerful ones,
> but i might check that out. i've generally found the oil not to make
> much difference in the tomos motors shifting.
You're right, the spring in 2nd gear is what controls the upshift for the most part..but i have noticed a little bit better slip characteristics with oil instead of ATF, especially when the engine is heat soaked.
The real reason I use atf though is to help preserve the soft countershaft gears, and also help quiet the gear whine a little.
My bike makes a good bit of power, and I use a jammer clutch as well.
I notice less metal flake in my oil changes with actual oil.
When I used to use atf, I noticed burrs forming on the countershaft gear teeth and lots of metal flake.
  Puch E50 Clutch Fluid AdventuresTopic by: Dan (high idle) Conway Dan (high idle) Conway 10/15/19 10:54PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 10/16/19 02:57AM
  Re: Puch E50 Clutch Fluid AdventuresRe: * wormdirt * * wormdirt * 10/16/19 10:26AM
  Re: Puch E50 Clutch Fluid AdventuresRe: P D P D 10/16/19 12:14PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 10/16/19 01:29PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * wormdirt * * wormdirt * 10/16/19 02:37PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Adam Smith Adam Smith 10/16/19 08:01AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/16/19 12:39PM
  Re: Puch E50 Clutch Fluid AdventuresRe: niklaus _ niklaus _ 10/16/19 01:20PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/16/19 05:10PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Daniel '' Daniel '' 10/16/19 09:16PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Mike Boyd Mike Boyd 10/16/19 01:51PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/16/19 02:19PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Mike Boyd Mike Boyd 10/16/19 03:12PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Jeff Parr Jeff Parr 10/16/19 04:49PM
  Re: Puch E50 Clutch Fluid AdventuresRe: EH FCC of the QCB EH FCC of the QCB 10/17/19 07:40AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brad William Brad William 10/16/19 08:45PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/17/19 04:47PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/17/19 06:03PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/18/19 01:32PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Adam Smith Adam Smith 10/18/19 05:03PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/20/19 11:13AM
  Re: Puch E50 Clutch Fluid AdventuresRe: ken gilbert ken gilbert 10/21/19 06:22AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/21/19 10:29AM
  Re: Puch E50 Clutch Fluid AdventuresRe: EH FCC of the QCB EH FCC of the QCB 10/21/19 01:33PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dirty30 Dillon Dirty30 Dillon 10/17/19 02:20PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 05:11PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/17/19 06:02PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 06:39PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 08:40PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Chris Squid Chris Squid 10/23/19 12:41PM
  Re: Puch E50 Clutch Fluid AdventuresRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/23/19 01:33PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/05/19 11:15PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 11/05/19 11:58PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/06/19 08:00PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Seth B Seth B 11/06/19 08:10PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/06/19 10:27PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 11/06/19 11:28PM
  Re: Puch E50 Clutch Fluid AdventuresRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/06/19 10:56PM
