Re: Puch E50 Clutch Fluid Adventures
Graham Motzing /
the oil in your transmission goes from whatever temp it is outside to probably 180-250 degrees when the engine is running, so the air temp swing really doesn't make much difference compared to the difference between hot/cold running.
  Puch E50 Clutch Fluid AdventuresTopic by: Dan (high idle) Conway Dan (high idle) Conway 10/15/19 10:54PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 10/16/19 02:57AM
  Re: Puch E50 Clutch Fluid AdventuresRe: * wormdirt * * wormdirt * 10/16/19 10:26AM
  Re: Puch E50 Clutch Fluid AdventuresRe: P D P D 10/16/19 12:14PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 10/16/19 01:29PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * wormdirt * * wormdirt * 10/16/19 02:37PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Adam Smith Adam Smith 10/16/19 08:01AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/16/19 12:39PM
  Re: Puch E50 Clutch Fluid AdventuresRe: niklaus _ niklaus _ 10/16/19 01:20PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/16/19 05:10PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Daniel '' Daniel '' 10/16/19 09:16PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Mike Boyd Mike Boyd 10/16/19 01:51PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/16/19 02:19PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Mike Boyd Mike Boyd 10/16/19 03:12PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Jeff Parr Jeff Parr 10/16/19 04:49PM
  Re: Puch E50 Clutch Fluid AdventuresRe: EH FCC of the QCB EH FCC of the QCB 10/17/19 07:40AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brad William Brad William 10/16/19 08:45PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/17/19 04:47PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/17/19 06:03PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/18/19 01:32PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Adam Smith Adam Smith 10/18/19 05:03PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/20/19 11:13AM
  Re: Puch E50 Clutch Fluid AdventuresRe: ken gilbert ken gilbert 10/21/19 06:22AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/21/19 10:29AM
  Re: Puch E50 Clutch Fluid AdventuresRe: EH FCC of the QCB EH FCC of the QCB 10/21/19 01:33PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dirty30 Dillon Dirty30 Dillon 10/17/19 02:20PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 05:11PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/17/19 06:02PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 06:39PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 08:40PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Chris Squid Chris Squid 10/23/19 12:41PM
  Re: Puch E50 Clutch Fluid AdventuresRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/23/19 01:33PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/05/19 11:15PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 11/05/19 11:58PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/06/19 08:00PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Seth B Seth B 11/06/19 08:10PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/06/19 10:27PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 11/06/19 11:28PM
  Re: Puch E50 Clutch Fluid AdventuresRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/06/19 10:56PM
