Re: Puch E50 Clutch Fluid Adventures
Graham Motzing /
> Brad William Wrote:
> Is it really the case that slip/lubricity/viscosity are the only
> variables to all of the above? I was of the impression that some fluids
> were more/less compatible with the clutch pad material itself. Don't
> some formulations, never intended for wet clutch use, deteriorate the
> pads chemically?
so this is pretty complicated because there are a number of different materials/chemicals at play. i've never experienced any chemical reaction problems from running different oils, but the rubber clutch in a Garelli NOI is the big one.
for the most part all of these oils are pretty chemically inert with the clutch and seal materials in the transmission. The a35 cork could be another one that would be harmed by detergent or solvents in the oil, but those probably won't live long enough to need it.
interesting about the rotella in the A35's, i've always ran those with ATF because i usually go to asbestos linings on the more powerful ones, but i might check that out. i've generally found the oil not to make much difference in the tomos motors shifting.
  Puch E50 Clutch Fluid AdventuresTopic by: Dan (high idle) Conway Dan (high idle) Conway 10/15/19 10:54PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 10/16/19 02:57AM
  Re: Puch E50 Clutch Fluid AdventuresRe: * wormdirt * * wormdirt * 10/16/19 10:26AM
  Re: Puch E50 Clutch Fluid AdventuresRe: P D P D 10/16/19 12:14PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 10/16/19 01:29PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * wormdirt * * wormdirt * 10/16/19 02:37PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Adam Smith Adam Smith 10/16/19 08:01AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/16/19 12:39PM
  Re: Puch E50 Clutch Fluid AdventuresRe: niklaus _ niklaus _ 10/16/19 01:20PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/16/19 05:10PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Daniel '' Daniel '' 10/16/19 09:16PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Mike Boyd Mike Boyd 10/16/19 01:51PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/16/19 02:19PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Mike Boyd Mike Boyd 10/16/19 03:12PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Jeff Parr Jeff Parr 10/16/19 04:49PM
  Re: Puch E50 Clutch Fluid AdventuresRe: EH FCC of the QCB EH FCC of the QCB 10/17/19 07:40AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brad William Brad William 10/16/19 08:45PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/17/19 04:47PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/17/19 06:03PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/18/19 01:32PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Adam Smith Adam Smith 10/18/19 05:03PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/20/19 11:13AM
  Re: Puch E50 Clutch Fluid AdventuresRe: ken gilbert ken gilbert 10/21/19 06:22AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/21/19 10:29AM
  Re: Puch E50 Clutch Fluid AdventuresRe: EH FCC of the QCB EH FCC of the QCB 10/21/19 01:33PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dirty30 Dillon Dirty30 Dillon 10/17/19 02:20PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 05:11PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/17/19 06:02PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 06:39PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 08:40PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Chris Squid Chris Squid 10/23/19 12:41PM
  Re: Puch E50 Clutch Fluid AdventuresRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/23/19 01:33PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/05/19 11:15PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 11/05/19 11:58PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/06/19 08:00PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Seth B Seth B 11/06/19 08:10PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/06/19 10:27PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 11/06/19 11:28PM
  Re: Puch E50 Clutch Fluid AdventuresRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/06/19 10:56PM
