Re: Puch E50 Clutch Fluid Adventures
Graham Motzing /
yeah everyone has different preferences when it comes to trans fluid. I like to run the 15w40 rotella in my e50's and i like to run the 10w40 'valvoline motorcycle oil' in my ZA50.
you get a little more slip on the rotella
in my experience from least-most slip:
ATF type F
ATF dex/merc 3 (very slightly more slip, imperceptable on most setups)
0w20 mobil one (my wife's car uses it so i have it around)
10w14 valvoline motorcycle oil - now the difference between the 0w mobil one and the valvoline motorcycle is that the clutches in the 2 speed will 'stay locked' better with the valvoline, the 0w they will grab about the same but especially when its warm it will downshift sometimes when you dont want it to which gets annoying
10w40 car oil generic pennzoil- sometimes slips more sometimes slips less, i don't like using this vs the motorcycle oil because it changes a lot with temp. feels great when its cold but gets grabby hot.
15w40 rotella - i like this a lot in the e50, i also like that you can leave the springs a bit less pressure and get the same effect which means less wear and tear on the clutches
gear oil would go above this- 80w90 gear oil- personally i have avoided this because i've never needed it
  Puch E50 Clutch Fluid AdventuresTopic by: Dan (high idle) Conway Dan (high idle) Conway 10/15/19 10:54PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 10/16/19 02:57AM
  Re: Puch E50 Clutch Fluid AdventuresRe: * wormdirt * * wormdirt * 10/16/19 10:26AM
  Re: Puch E50 Clutch Fluid AdventuresRe: P D P D 10/16/19 12:14PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 10/16/19 01:29PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * wormdirt * * wormdirt * 10/16/19 02:37PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Adam Smith Adam Smith 10/16/19 08:01AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/16/19 12:39PM
  Re: Puch E50 Clutch Fluid AdventuresRe: niklaus _ niklaus _ 10/16/19 01:20PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/16/19 05:10PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Daniel '' Daniel '' 10/16/19 09:16PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Mike Boyd Mike Boyd 10/16/19 01:51PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/16/19 02:19PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Mike Boyd Mike Boyd 10/16/19 03:12PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Jeff Parr Jeff Parr 10/16/19 04:49PM
  Re: Puch E50 Clutch Fluid AdventuresRe: EH FCC of the QCB EH FCC of the QCB 10/17/19 07:40AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brad William Brad William 10/16/19 08:45PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/17/19 04:47PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 10/17/19 06:03PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/18/19 01:32PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Adam Smith Adam Smith 10/18/19 05:03PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/20/19 11:13AM
  Re: Puch E50 Clutch Fluid AdventuresRe: ken gilbert ken gilbert 10/21/19 06:22AM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/21/19 10:29AM
  Re: Puch E50 Clutch Fluid AdventuresRe: EH FCC of the QCB EH FCC of the QCB 10/21/19 01:33PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dirty30 Dillon Dirty30 Dillon 10/17/19 02:20PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 05:11PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Graham Motzing Graham Motzing 10/17/19 06:02PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 06:39PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 10/17/19 08:40PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Chris Squid Chris Squid 10/23/19 12:41PM
  Re: Puch E50 Clutch Fluid AdventuresRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 10/23/19 01:33PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/05/19 11:15PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 11/05/19 11:58PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/06/19 08:00PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Seth B Seth B 11/06/19 08:10PM
  Re: Puch E50 Clutch Fluid AdventuresRe: Dan (high idle) Conway Dan (high idle) Conway 11/06/19 10:27PM
  Re: Puch E50 Clutch Fluid AdventuresRe: * * * * 11/06/19 11:28PM
  Re: Puch E50 Clutch Fluid AdventuresRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 11/06/19 10:56PM
