Brand new to this. Previous owner threw on a killer exhaust, which ran great with him on it. But I'm a little heavier and I was hoping to get a little more out of this engine, since otherwise it runs great and hasn't given me any problem turning over. Only issue I have is starting from a dead stop or working my way up hills. Hoping there's some kind of limiter I can drill out or shave off, fuel additive I could try, or really anything to give it a little more kick without breaking the bank. I appreciate all the information I was able to find already, and thanks in advance for keeping me on two wheels!!
Need advice for beefing up a PA50ii
Re: Need advice for beefing up a PA50ii
You could change variator weights and clutch springs
Perfect, I'll look into that
What exhaust? Did the prev owner upjet the carb accordingly?
Stiffer clutch springs will engage at higher RPM and provide more power @ take-off.
Start with 1500rpm
After-market variators are easier to tune for the acceleration and top end you're looking for.
18 to 21g total weight is a good place to start with a DOS or TJT.
treatland does have these variator weights that fit in the stock 3 roller, in case you want a $10 option vs the $120 one (tjt).
Stock pa50II weights are 14g each, fyi.
You will want to get a good strap wrench and socket that fits the big nut on the variatior, I forget the size and can't get out to the garage right now, I'm sure someone here knows.
DR kit.
I just brap the big nut off with an impact. Generally unless the contra is worn out super bad the stock weights are great for a stock kit with a pipe. I would say some mild springs in the clutch, you will need a clutch puller and a pick or vise grips to install them.
