Did you do the clutch springs? It’s a huge improvement for an E50.
> Thomas Peffer Wrote:
> Went with the estoril pipe and ditched the boss. Also did some base
> spacing with 3 base gaskets from treats so the piston will clear the
> exhaust port & transfers. Also opened up/widened the exhaust port just a
> bit (like 2mm or so) and geared out to 18/42. Using a 15mm bing carb
> with matching 15mm Grandpas intake with 78 jet, needle on leanest
> setting with metal mesh hi-flow filter
