Re: NU50 Rebuild vs Kitted
Captain Janeway /
Not sure what you're doing with the throttle cable. Do you think it's stretched? sticking?
since it seems to change every time you open the carb I have to ask: are you putting the slide in right (p. 41in the manual). If you put it in backwards it's going off to the races because the slide won't move properly.
Look into the carb with the airbox off, twist the throttle, and let go. You should see that slide move up, then snap back down when you let the throttle go. When you're looking in, you will see a gap at the bottom of the slide.
If you've been playing with that cable, yeah you may have to spend a little time adjusting it now, but see if that slide's in correctly.
  NU50 Rebuild vs KittedTopic by: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 09/24/19 02:23AM
  Re: NU50 Rebuild vs KittedRe: Captain Janeway Captain Janeway 09/24/19 11:29AM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 09/24/19 12:12PM
  Re: NU50 Rebuild vs KittedRe: P D P D 09/24/19 02:27PM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 09/24/19 03:04PM
  Re: NU50 Rebuild vs KittedRe: Captain Janeway Captain Janeway 09/24/19 03:26PM
  Re: NU50 Rebuild vs KittedRe: P D P D 09/24/19 07:04PM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 09/24/19 11:42PM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 09/25/19 12:21AM
  Re: NU50 Rebuild vs KittedRe: P D P D 09/25/19 09:01AM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 09/25/19 06:29AM
  Re: NU50 Rebuild vs KittedRe: Captain Janeway Captain Janeway 09/25/19 11:37AM
  Re: NU50 Rebuild vs KittedRe: P D P D 09/25/19 01:41PM
  Re: NU50 Rebuild vs KittedRe: Captain Janeway Captain Janeway 09/25/19 02:05PM
  Re: NU50 Rebuild vs KittedRe: Dirty30 Dillon Dirty30 Dillon 09/25/19 03:07PM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 10/02/19 12:09AM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 10/02/19 07:18PM
  Re: NU50 Rebuild vs KittedRe: Captain Janeway Captain Janeway 10/02/19 10:35PM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 10/04/19 08:07AM
  Re: NU50 Rebuild vs KittedRe: Captain Janeway Captain Janeway 10/04/19 10:20AM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 10/06/19 12:42AM
  Re: NU50 Rebuild vs KittedRe: Captain Janeway Captain Janeway 10/06/19 12:13PM
  Re: NU50 Rebuild vs KittedRe: Smitty Werbenjegermanjensen Smitty Werbenjegermanjensen 10/06/19 05:41PM
