Re: Hpi With a DC pump.
Steven S /
literally remove the battery and replace it with a capacitor, make sure the capacitor is capable of >the peak positive unloaded output of your charge coil and you will be fine. the larger the capacitance the better, use an electrolytic capacitor. Of course you will find with a cap at idle you may not be able to produce enough energy to charge the cap and your pump/lights/whatever may not work unless at speed.
