> Pavo Z Wrote:
> I use capacitor instead of battery on mine 103.
> Only thing i do not understand about floated ground, if there is no
> ground what happen to excess wattage in circuit? Like, coil produce 15w,
> pump use 6.. is it still grounded trought rectificer/frame? Or will
> something burn out if everything isnt used?
If regulator/rectifier is rated high enough to deal with the excess, no problemo
