Re: Hpi With a DC pump.
Jesse Simonsen /
> Travis Noll Wrote:
> Just get a full bridge rectifier. Light coil out to AC+, ground to AC-.
> Then run dc stuff after that of your choice.
> With pumps, running some sort of battery in line is smarter than having
> draw straight off of the flywheel. Not to say you HAVE to, but motors
> like clean and constant current/voltage.
Thanks. That's what I thought would work. Gonna put a small battery on after the rectifier. I just started getting confused after reading all the past threads about rectifying. Didn't know if it was as effective this way.
