Re: Hpi With a DC pump.
Jesse Simonsen /
What would be the best way to get DC off of an Artek ignition? They are single wire and the coils are encased just like the MVT internal rotors so floating is not an option.
Would running the light wire to the Trail Tech rectifier and grounding the ac- to frame then taking the dc to a battery and pump while floating the dc grounds work? Would I get 12+ v dc?
Trying to figure out if my only option is to run a battery total loss and charge when needed.
I'm only concerned about running a pump and a couple guages. I have 60 watts to work with so I could run ac lights
