> Joseph Waldridge the 2nd Wrote:
> If you take one of your smaller Jets and drill it bigger than the 180 it
> will never hurt anything.... But it's all about that needle I keep it in
> the center and make sure you tune that airscrew.... I found the easiest
> way to tune the air screw on the mikuni VM carburetors.... Is by
> starting your bike up and letting it get to correct temperature.... Then
> adjust your idle screw so it's idling high and fast..... Then take that
> are screw and by starting it around a half a turn out keep on turning it
> until your bike idles really high and fast... You should be able to keep
> turning until it starts to come back down... If not your jets are too
> big.... But either way three or four or five turns out and then
> adjusting your idle back down using the idle screw....Will definitely
> help in getting a faster response... I ran the mikuni vm18 for almost a
> year and it ran great but as soon as I find tune that screw oh my
> goodness it helped with everything... Plus I install the four petal
> reading take that did wonders ripping dicks now...
Thanks, I havent started tuning the carb yet, but I do think a 180 might be too big to start.
