> Brandon Weiss (Detective brandon to you) Wrote:
> > Maserat Maserat Wrote:
> > > Thomas Peffer Wrote:
> > > Just seeing what speeds you guys are getting with the 70cc Kstar kit
> > and
> > > what setups do you run? I'm running a 70cc Kstar with 15mm Bing, #74
> > > jet, stock Puch head, techno boss pipe with 16/42 gearing and it
> gets
> > my
> > > 1980 Puch Maxi Luxe to 50 mph on flat roads
> > How is it on hills? I just finished a 70cc treats with a touring
> head,
> > 15mm bing #79 jet, proma circuit pipe, 15/45 gearing on an 84 Maxi. I
> > pull good up steep hills but am topping out at 31 on the flats. I
> want
> > to change the pipe but I live on a steep hill.
> 31 is terrible for that gearing, you arent revving like you should. You
> should be doing just about 40-41 with that gearing and setup properly
> tuned.
> Did you verify your timing with a light?
Yes, I also used a dial indicator to find tdc so unless my light is off its spot on. I did find that with the points set to .016 even with dremeling the stator I can't get below 17 degrees, I set the points to around .014 and got the timing down to 15 but it ran poorly. I plan on getting a tach and probably a different pipe.
