Re: Buzzards vs Barons Vogue Single Speed Build Off
I’ll pm ya will!
Dos IS BOSS as usual! Now to get it bolt up stock as possible to get a base line of performance before I get started modifying. Stay tuned!
So I got bored today and decided to throw the engine on. My stock Gurtner is fucked so I threw a stock 14.12 on and took it for a spin. It was for stroking on top end so I had to feather the throttle. I tried to rejet it but someone drilled it the 53 jet to something way larger than a 61 so I have to play with it more to figure out jetting. I'm thinking it's around a 70? I'm running no filter yet so I know that has something to do with it also. Going to order a petcock and air filter and go from there.
It actually sounds pretty good!
Got me hatter blockers on!
I always wondered why everyone smiles at me when I have mine on . ;)
Josiah Radebaugh /
How much lower will that SHA allow for an idle?
I am confused what do you mean? Please elaborate.
Pulled the reeds.....and bummed... I was going to use the metal reeds to make a set of dual stage reeds.....but that idea is out. Going to hack it up and make one big flapper? Like people do to derbis? Idk verdict is still out.
Got sick of staring at this kit and using the sharpie to mark something only to remove it.....got a 12 pack of Bush Latè and said fuck it I am going in.
Porting is 100% done. I need to hone they cylinder.
I started on the piston but got tired. Noting too crazy going on with it. Just going to window it and added a couple small holes hear and ther.
I am sweeting this pipe thing! Like fuck. This dumb porting could be cool with a pipe. But stock moded pipe?!? Idk still looking for suggestions on that department.
Oh and all those weird males in the gasket are is just from where I use a plastic razor to remove the old gasket material. Mating surface is totally fine. I only had one slip up by one of the auxiliary ports....hope the hone take care of that.
I have a big box of NOS metal lollipop reeds. I'll set you up. Lookin good!
> good!
Sweeeet! Thanks dude!
Anonymous User /
scootertrash
This worked like a champ. A long bit with 320 grit glued and taped. Lots of lube, I used wd40.
Check iT
Sooooooo the Vogue uses a different petcock from the standard 10mm mbk/pug petcock. It's like 12mm?
I'm not buying a part for this unless I completely/no other way have to. Wish me luck!
Josiah Radebaugh /
@ Barron I was asking how low a sha can idle, but then I remembered I'm an idiot. Sooo disregard that! This build is dope, cant wait to see the final product! Have you considered the clone tilitson carbs? 18mm at 15 bucks on amazon, I've heard they're pretty great for the money.
So all that work and I couldn't save the petcock. But hey the tank doesn't leak!
Getting there! Gearing is 11/46
Anonymous User /
scootertrash
Another job well done., Ur a gentleman and a scholar.
Before bottom. Ported on the top.
Ugh I can’t stop looking at this.....so fresh. Hope it works. Won't have much time the next few days but going to get back on the grind on Monday.(edited)
So I did a thing today.
First step
Second step.
Ready for assembly baby! We gots a whole 15mm!
Not bad! 3mph just by modifying the stock carb.
Josiah Radebaugh /
Charge your phone
Anonymous User /
scootertrash
Easy money!
> -------------------------------------------------------one....
> Charge your phone
Then I'd have to hold a long conversation with someone.........
