Re: Buzzards vs Barons Vogue Single Speed Build Off
Gotta love it! Fix one problem just to create another.....
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
There’s a hole in it. ;)
Why not relieve the piston head at the ports and use a much thinner spacer ?
Then just take a bit off the head mating surface .
Might not be perfect , but , it would be a lot less hassle and likely cheaper to boot .
> spacer ?
> cheaper to boot .
The cylinder is at the machine shop as we speak ;)
OK . Never mind . ;)
Out of curiosity , how much for that^ operation ? (edited)
To machine the top of the cylinder? $50
All considered , not too bad .
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
beats going at it with a plate of thick glass and some sand paper
Damn. That is why I just modified the piston crown. I don’t have a machine shop on speed dial!
Matt just got back to town. I need to go pick up the pipe. He also has a stock reed block wish he had a spare single speed clutch to modify. Last night Stephen and I had some ideas.....
U can anneal the spacer with a candle and torch.
So while waiting for my cylinder to come back I was looking at my front forks. They are pretty much screwed! They keep locking up and when I tried to to take them apart so I could attend to clean them up stuff started breaking plus the tubes are slightly bent.
Sooooooo I went digging in my parts stash again. I'm probably going to need some different bars but it's all I had at the moment.
My wire harness was chopped up and "I" singed it when I was fixing the tank so I'm going to extend it and fix where I singed it at.
Just watching this. Thanks!
So I swapped from a 2.5mm base spacer with gaskets to a 2mm bases spacer with copper spray. The cylinder being decked make it look almost perfect!
Got it all sewed up to torqued down.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
copper spraaaaaay!
> the worst terry Wrote:
> copper spraaaaaay!
Yes sir! I keep a can on the back shelf in the corner for emergencies like this ;)
So I added pedals, crank arms, a old head light I had laying around and a lunch box to the rear of my seat to hold a half of a bologna sandwich and a nip for the winter days ahead.
Nice. I think hondabond/threebond/motoseal would have been a better choice for the base, just because of the nature of the surface vs the head/cylinder joint. You have the 2 case halves which can be misaligned/non-coplanar ever so slightly, and the cross section of the center gasket too, which the hondabond would probably fill in better.
I'm eager to see this thing run
Possibly. I only had copper spray on hand so I tried it. Either way I'm going to have to use some kinda sealed on it. Luckly it doesn't swing from the head like MBK.
So since I'm going to be running side covers and a thumb lever is already there I drilled/tapped my carb and added a choke.
But , won't two different rear shocks make you go 'round in circles ? LOL
And , you'll likely be thankful you did the slick choke thing , too . ;)
> LOL
LOL, it hasn't yet. I noticed that today and haven't decided when I'm going to change them.
I know I will. It starts easily without the choke but keep shutting off at throttle response it terrible until she warms up.
We at it again.
She's alive!!! Be back later...
A little minor setback. Will have it fixed up in a few.
Starter springs?
Next time yall have to do this in 8 hours at the warehouse using only tools provided. Michael will film it. Itll be like Junkyard Wars. I'll plant rotary tools and cheater stock parts in the mix of junkers.
I'm game! Yes starter spring broke.
