Re: Buzzards vs Barons Vogue Single Speed Build Off
> Baron Von Hamilton Wrote:
> Funny caus Stephen was messing with his coolant system in his Explorer
> all day today! Coolant system build off coming soon to Off Topic.
LMFAO, say it ain't so!!!!! At least you didn't have to go through what I had to go through......
Had to plastic weld this back because of my mistake of course....
Got this from harbor freight for like $15 I think? It works pretty good if I must say so myself.
Going for lunch was a blast though and made it all alright!
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
Oh shiT, glad ur back together on the Exploder, the pics make it look easy ;)
> easy ;)
It's really not hard just time consuming and patience needed. It's one of those things that you can't think about before doing it you just have to do it or you'll talk yourself out of it........
I do this so goddamned much, it isn't funny.
> have
LOL
Me too. Maybe it comes with age. When I was younger I would just rip shit apart get in over my head then figure out a way to make it work. Now I am like damn....I know where this road leads to and I don’t want to go down it.....
"Experience is what enables you to recognize a mistake when you make it again." ;)
> to go down it.....
Honestly, I probably would have burnt the Expedition if it wasn't what I use to go to rallies and pull my trailer full of bikes..... It does a good job of it too. (edited)
I thought about replacing the heater core in my Ranger.... got about half way there and decided I didn’t care that much.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
i went through the same shit with my xj a while back, it was the worst. it's nice having a heater, though!
I can live with a/c, but a heater!? That’s a MUST! Even if it just works well enough to defrost the windshield.
You guys are killing it love this thread.
Amen
GET BACK TO THE BUILD OFF OR I'M SENDING YOU TO OFF TOPIC!!
so pumped
Don’t thinK DOOooo
LMFAO, okay.....
You somza bish! Noooooo!
Hahaha
So waiting on a hack and weld stock pipe from Gator, he gets back on Friday! I think I am going to slap on some lighter reed paper for the second stage reeds. I wonder if 0.3 mm is to thic...? Idk the rulz of reed paperz. Also super busy with work right meow.
That’s perfect thickness.
That is what I thought. Just looking for someone to testify! I am thinking it has to be that I hacked the exhaust up into a coffee can on a stick.
When I plastic weld shit likw that I like to melt some steel wool in there too. it's like zero extra effort and makes it way stronger
Did a little more work. Well what do you know, I have the 39.88mm cylinder which is the smallest made. They go up to 39.96 so I have to gap the rings along with modify where the location pin sits in the rings so it'll fit.
Piston in the cylinder
$5 score!
Heavy duty tin foil ?
Basically, 2mm thick aluminum so I can make base spacer.
Now let's see if ports are open.
