Re: Buzzards vs Barons Vogue Single Speed Build Off
Dirty30 Dillon /
Totally correct, I did not see the nut.
Tomos did have odd year A35 Classic models that had two petcock positions, one for Male thread and one lower for female threads to avoid having to stamp different frames for the same year ST's that either came with the A55 (standard ST) or the A35 Classic restricted models that were sold in some funky countries.
Just got off the phone with Stephen we are stoked too see the responses to this. We are having so much fun building out bikes. I am bummed I am so slow to get to work on everything. Damn life getting in the way. I should get my motor back together tomorrow night and the exhaust welded up on Monday! Then I’ll be ready for a test run! If everything goes will I’ll get to some of the cosmetics on Monday as well. This may be my new favorite bike. Best part is that mine will be the fastest!
> Baron Von Hamilton Wrote:
> This may
Hey hey hey grasshopper! We shall see.....
Here we go!
Hell yeah, Stephen!
this is where the bullet hits the bone.
or something.
Did blake not have the 12x1 petcock? I swear I got one from them like 2 years ago. probably was 10mm actually
> or something.
I asked and he said if he did he couldn't put his hands on the.
I'm still at it!
Going to keep this simple.
Let's see how this works.
Starter Clutch came out good!
Yes sir it did! About to send you a video on how it goes back together. I actually just finished making one.
Thanks man! I appreciate it! Got it! Post it here for anyone who may needs it....like If they accidentally drop it on the ground. ;)
Base gasket all done ✅
So it would not clear the transfers. Best bet would be to mill the kit down and add a base gasket. Don’t have a late and don’t want to sand it. So I adjusted the piston. I did this to a MBK kit before it worked well. I am sure it lowered compression but I would rather have the transfers open more. I went a little too much on the exhaust but I am not worried.
All buttoned up. Head torqued down to 125inch lbs. Carb from Stephen should be here tomorrow. I’ll have time on Monday to do the exhaust and take it for a rip! House work calls tomorrow and Sunday I am going 4 wheeling. So Monday it is..... Idk may still mess with the pipe this weekend. So so so so so so excited! Most fun I had building a bike in a while.
All for the love of it! Buzzards are the best....But my bike will still be faster. (edited)
Aux exhaust ports on a single speed... you might be fighting to get that clutch to stay slipping and not dumping the starter clutch at 10mph. Did you happen to get durations before you buttoned it all up?
𝐿𝑖𝑘𝑎-𝐿𝑜𝑡𝑎𝑠𝑎𝑢𝑟 𝑀𝑒𝑔𝑎𝑝𝑢𝑠 🦖 /
One of my favorite things is blowing thru the reed valve making a honk sound. :)
> sound. :)
LOL, I thought I was the only one who does that.
The audience wants more!!
> sound. :)
Hahaha mine too!
I did not measure the ports, calculate blow down or do a port map. :/ Recently I started keeping port maps on kits I was porting because someone would always ask. I don’t know how it will do as a single speed with a stock exhaust. We shall see? I know the exhaust is not more than 45-50% of the bore and I only raised the main window like 2mm.
I keep telling myself single speed don’t go to nuts......
Exhaust is done!
Going to match transfers. Marking bottom end before I tear it apart and rebuilt it.
Time to clean up and rebuild! Be right back.
Now on to the cases
Going to eat lunch with my wife then coming back and knocking the transfers out.
Dug ole Bertha out.
Big Bertha has done it again!
