> Lee Snover Wrote:
> > Overpriced Parts Wrote:
> > > Lee Snover Wrote:
> > > > Seth B Wrote:
> > > > Lee, case matching has to be done with pretty much any kit.
> > > OK, I did some reading and the concensus is it's not 100% necessary,
> > but
> > > highly beneficial. I will see how it looks on my stock motor. I
> want
> > > to try it out with that motor while I build another motor that I
> don't
> > > mind cutting on.
> > > I'll be doing things one at a time. 15mm Bing, Air Filter, Circuit
> > > Pipe, last will be the Polini. Want to introduce changes slowly.
> > Too
> > > much too fast makes it hard to diagnose problems. I'll be setting
> > this
> > > up very conservative at first, keep it rich and 16 degrees on
> timing,
> > > done with a proper light.
> > Cutting of the boost ports at the top is a must or or you could seize
> > The gasket that comes with the kit will show you how to cut, it
> > t doesn’t have to be very deep at all just a little bit to let some
> gas
> > mix to get in there!
> OK, I'll keep reading, and see how it looks. I really don't want to
> tear that case down before winter. If I can do it without tearing it
> apart I'll try. Need to wait for next sale to get a Stuffed ZA50 crank
> and the bits to do the rebuilds. I have 3 motors that need to be
> rebuilt, so lots of practice to do. But one is running good, so I don't
> want to mess with it much until I have another one in good shape.
> My big Treats order came early, so I can play with the python pipe and
> other goodies this weekend. Getting Maxi Sport#2 on the road so my wife
> can buzz the town with me. Lots of old tires to replace and grease to
> scrub. Woo hoo!
laying some plastacine / clay or in the uk we call it blu-tack in the bottoem end to stop metal filling the crank. you should be able to do quite a lot insitu with the crank suffed with cray/playdoh
