> Lee Snover Wrote:
> > Seth B Wrote:
> > Lee, case matching has to be done with pretty much any kit.
> OK, I did some reading and the concensus is it's not 100% necessary, but
> highly beneficial. I will see how it looks on my stock motor. I want
> to try it out with that motor while I build another motor that I don't
> mind cutting on.
> I'll be doing things one at a time. 15mm Bing, Air Filter, Circuit
> Pipe, last will be the Polini. Want to introduce changes slowly. Too
> much too fast makes it hard to diagnose problems. I'll be setting this
> up very conservative at first, keep it rich and 16 degrees on timing,
> done with a proper light.
Cutting of the boost ports at the top is a must or or you could seize
The gasket that comes with the kit will show you how to cut, it doesn’t have to be very deep at all just a little bit to let some gas mix to get in there!
