> Seth B Wrote:
> Lee, case matching has to be done with pretty much any kit.
OK, I did some reading and the concensus is it's not 100% necessary, but highly beneficial. I will see how it looks on my stock motor. I want to try it out with that motor while I build another motor that I don't mind cutting on.
I'll be doing things one at a time. 15mm Bing, Air Filter, Circuit Pipe, last will be the Polini. Want to introduce changes slowly. Too much too fast makes it hard to diagnose problems. I'll be setting this up very conservative at first, keep it rich and 16 degrees on timing, done with a proper light.
