Re: Importance of float level
Rocco Taco /
> Graham Motzing Wrote:
> EX:
> just after posting i remembered a really good example of this. Due to
> manifold constraints and packaging i went from a VM22 on a moped build
> to a VM18. Despite being similar design and layout, these two carbs are
> (obviously) different castings and always end up running really
> different tuning parts.
> I had a 165 jet in the VM22, when i put the VM18 i was running a 75 jet.
> since mikuni jets are sized based on fuel flow, its easy math to see
> that dropping the jet size resulted in a (1-(75/165))= 65% decrease in
> flow rate through the jet.
> now, the speed of the moped didn't decrease much, and it was properly
> tuned in both scenarios, which means we can assume that mass air flow
> rate stayed relatively constant and fuel flow rate stayed relatively
> constant.
> so, because mikuni did the hard work for us and linearized the mass fuel
> flow rate of the jets, the math is really easy to say that (give or
> take) there was a 65% increase in differential pressure across the main
> jet to accomplish the same mass fuel flow rate with a smaller jet.
> so the differential pressure of having a different float level setting
> as a percentage change in mass fuel flow rate decreased by a factor of
> whatever that pressure drop is. if you wanted to just make up some
> numbers as an example you could say that the main jet delta p on the
> VM22 was, lets say, 10 cm. So then the 65% increase on the VM18 needs
> the pressure to to be (10/.45)= 22.2 cm differential to make the same
> mass flow rate. Now if you are .2 cm off on your float level, on the
> VM22 that will be a (.2/10) =2 % change in mass flow rate, whereas if
> you are .2 cm off on the VM18 it will be a (.2/22.2)= 0.9% change in
> mass flow rate.
> I think that math is right but i'm not super sure that you can use the
> mikuni jet size flow rates in a linear fashion like that, either way it
> shows a pretty good example of how the original poster is way the fuck
> wrong.
I’m definitely wrong too!
  Importance of float levelTopic by: Michael Forrest Michael Forrest 08/28/19 11:16AM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 11:44AM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 11:46AM
  Re: Importance of float levelRe: jayson sumpter jayson sumpter 08/28/19 12:00PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 11:52AM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 11:58AM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/28/19 12:15PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 12:26PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 12:34PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 12:42PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 01:37PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 03:05PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 03:34PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 04:06PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 04:12PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/28/19 01:59PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 03:15PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 04:07PM
  Re: Importance of float levelRe: Braedan Cvetkovich Braedan Cvetkovich 08/28/19 04:50PM
  Re: Importance of float levelRe: ken gilbert ken gilbert 08/28/19 04:55PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/28/19 05:13PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 07:02PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 09:15PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 09:36PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/28/19 09:51PM
  Re: Importance of float levelRe: K Olena K Olena 08/30/19 11:25AM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/30/19 11:38AM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/30/19 11:56AM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/30/19 11:57AM
  Re: Importance of float levelRe: Graham Motzing Graham Motzing 08/30/19 11:58AM
  Re: Importance of float levelRe: Graham Motzing Graham Motzing 08/30/19 12:27PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/30/19 12:59PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/30/19 01:53PM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 08/30/19 05:33PM
  Re: Importance of float levelRe: Overpriced Parts Overpriced Parts 08/30/19 07:28PM
  Re: Importance of float levelRe: baird co baird co 09/01/19 01:17PM
  Re: Importance of float levelRe: Norris Hall Norris Hall 09/02/19 10:25AM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 09/02/19 05:38PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 09/02/19 08:03PM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 09/03/19 06:04PM
  Re: Importance of float levelRe: Norris Hall Norris Hall 09/02/19 06:57PM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 09/03/19 06:03PM
  Re: Importance of float levelRe: Norris Hall Norris Hall 09/02/19 06:59PM
  Re: Importance of float levelRe: Norris Hall Norris Hall 09/04/19 12:42AM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 09/04/19 06:05PM
