Re: Importance of float level
Michael Forrest /
To prove that the suction pulling the gas up is due in only a very small amount to the Bernoulli effect, I want you to consider that effect only happens when there is a change in flow area so that under the front of the slide, when it is fully or partially closed, the area is smaller and so the flow is faster than before it and after it and so the Bernoulli effect creates vacuum there which acts mostly on the idle jet which is under the front of the slide. The needle and main jet are before this contracted area but still are at a slightly contracted area being under the middle of the slide. So the Bernoulli effect acts mostly on the idle jet and a little on the needle/main jets. Like I said before, there is some vacuum all the way between the engine and the air filter which acts on the jets, pulling up fuel from the float bowl which is at normal air pressure since the bowl is connected to outside air pressure via a breathing tube.
There is also a vacuum wave which some carbs make extra use of by the raised half shrouds extending up from the needle jet. They catch more of that wave and so the higher the shroud, the smaller the jets need to be.
  Importance of float levelTopic by: Michael Forrest Michael Forrest 08/28/19 11:16AM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 11:44AM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 11:46AM
  Re: Importance of float levelRe: jayson sumpter jayson sumpter 08/28/19 12:00PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 11:52AM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 11:58AM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/28/19 12:15PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 12:26PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 12:34PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 12:42PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 01:37PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 03:05PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 03:34PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 04:06PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 04:12PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/28/19 01:59PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 03:15PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 04:07PM
  Re: Importance of float levelRe: Braedan Cvetkovich Braedan Cvetkovich 08/28/19 04:50PM
  Re: Importance of float levelRe: ken gilbert ken gilbert 08/28/19 04:55PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/28/19 05:13PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 07:02PM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/28/19 09:15PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/28/19 09:36PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/28/19 09:51PM
  Re: Importance of float levelRe: K Olena K Olena 08/30/19 11:25AM
  Re: Importance of float levelRe: Michael Forrest Michael Forrest 08/30/19 11:38AM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/30/19 11:56AM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/30/19 11:57AM
  Re: Importance of float levelRe: Graham Motzing Graham Motzing 08/30/19 11:58AM
  Re: Importance of float levelRe: Graham Motzing Graham Motzing 08/30/19 12:27PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 08/30/19 12:59PM
  Re: Importance of float levelRe: live ɘvil live ɘvil 08/30/19 01:53PM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 08/30/19 05:33PM
  Re: Importance of float levelRe: Overpriced Parts Overpriced Parts 08/30/19 07:28PM
  Re: Importance of float levelRe: baird co baird co 09/01/19 01:17PM
  Re: Importance of float levelRe: Norris Hall Norris Hall 09/02/19 10:25AM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 09/02/19 05:38PM
  Re: Importance of float levelRe: Rocco Taco Rocco Taco 09/02/19 08:03PM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 09/03/19 06:04PM
  Re: Importance of float levelRe: Norris Hall Norris Hall 09/02/19 06:57PM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 09/03/19 06:03PM
  Re: Importance of float levelRe: Norris Hall Norris Hall 09/02/19 06:59PM
  Re: Importance of float levelRe: Norris Hall Norris Hall 09/04/19 12:42AM
  Re: Importance of float levelRe: Rebel Moby Rebel Moby 09/04/19 06:05PM
